Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th November 2007, 08:19 PM   #41
I'm using RS423'ed I2S as well, but I only needed one hole for a 9 pin d-type socket.
I'm sure SPDIF can be implemented well, but it is a further coding conversion method that can be made redundant, so why not as there is a risk it can impact the signal quality?
It also makes my DAC simpler, as I don't have to worry about implementing an SPDIF receiver.
Old 20th November 2007, 08:23 PM   #42
tubee is offline tubee  Netherlands
tubee's Avatar
I2S can also easily fed in/out with a simple one-hole (mini) DIN socket.
Daisy Bell
Old 20th November 2007, 09:00 PM   #43
QSerraTico_Tico's Avatar
No
Old 20th November 2007, 09:03 PM   #44
tubee's Avatar
shielding?
Daisy Bell
Old 20th November 2007, 09:05 PM   #45
shielding?
Transmission lines.
Each are 50-Ohm so you need 50-Ohm chassis parts and connectors. There is where Audio Alchemy failed.
Old 20th November 2007, 09:25 PM   #46
tubee's Avatar
Ok. Will omit DIN then
Daisy Bell
behringer Ultramatch Pro SRC2496 MAX MOD opinion needed lga775 Digital Line Level 1 5th February 2009 07:51 PM
Omnes audio L8spec - opinion needed barackuda Full Range 3 11th September 2007 10:42 AM
your opinion needed....... barackuda Tubes / Valves 3 30th August 2007 09:53 PM
Schematic opinion needed (guitar amp) Trout Tubes / Valves 8 2nd March 2006 02:35 AM
Opinion on those electrolytics needed Peter Daniel Parts 3 25th November 2003 04:12 PM
Page generated in 0.08077 seconds (69.92% PHP - 30.08% MySQL) with 11 queries
