| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I want to roll the (many) NE5532 opamps in my sony CDP-X505 ES players output stage. I've scanned its audio board schematics and color marked its opamps. Have a look here
http://www.beichel.at/x505es/audiobo...matic_x505.gif As you can see there are some dual and some single ops there (the "mix" ones are single i assume). Can you tell me which ones can be safely replaced w/ national's LM4562 or an equivalent (i have an eye on these and could get them for a good price) for better sound quality? I have heard that AD826 or OPA627 would be good, too. According to http://babelfish.altavista.com/babel...cdp777esa.html these 3-per-channel opamps are for "in buffer / GIC shape / LowPassFrequency" Well, i know what a LPF is but the other two functions? Would be glad if you could help me understand this better! Also, the IC607 seems to be a single opamp for DAC power supply, is this correct? (+5V) Would it be a sound improvement to swap this one, too? According to the above website: the two "final" opamps (OPA27GP) are IC405, IC505: for DC servo - Don't think these dc servo ops should be removed. Problem is, i've not that much experience in modding , but eventually i'll get a few DIP8 socket so i can swap opamps easily.A big THANK YOU in advance! Regards PS. further pics: http://www.beichel.at/x505es PS. The Sony X555, X557, X777, X779 and 707 have quite similar output boards, so If someone has successfully rolled opamps there, would be glad to hear from you! |
#2 |
Sony engineering at its best. Analog stage corrected in every possible way to reconstruct a proper sine-way (even it time domain), while adding a current boost and DC servo at the output. Not a single coupling cap in the whole path...
I have very similar output in my Denon, where I don't have mosfets in the output for current boost / low output impedance... However, I paralleled two halves of the AD826 (2 buffers working in parallel)... The sound is clean, easy to listen to - but lifeless!!! Ironed-out, boring, but still pleasant on the ear. I can see how people who never listened to live performances, or never experienced the sound of the recording master in a studio, can appreciate this kind of sound and be perfectly happy. You have 2 options; upgrade the existing stage, or add external differential-to-single-ended output stage. Install the IC sockets and try different combinations of AD826, LM4562, OP275. OPA627 is ridiculously expensive and I refuse to use it (in fact, I ditched BB / IT altogether for this reason). Try AD8066 which sounds even better if properly decoupled, and is a DUAL OP. Regards, Boky |
#3 |
The AD825 is a good choice on the output stage and use them on CDP-X55ES as well as CDP990.
Renewing some of the caps to feed these op amp can help as well. |
#4 |
I swaped almost all of the opamps in my Sony 505 (apart from the OP27 which is for DC-offset control) with op213(2)4, OP275 (filter), LM6172 (IC4/501 with local decoupling, for I/U conv) and that kind of stuff but couldn't really hear much of a difference. I also upgraded the analogue power supply caps and added more capacitance directly on the board (C617-620). It was a lot of work to desolder all the opamps and put some DIP8 sockets in. The DIP-sockets don't really fit but you can make it work. I don't think it was worth it.
What really made a difference imho was to replace the digital decoupling caps around the DAC with os-cons. All in all I was never satisfied with the sound of the Sony although I really like its mechanical appearance. It's a pity! May be the output stage is to complex? Or some jitter issues caused by multiple clocks? I would say start with the digital and analogue power supply upgrades and than may be think a about a new (opamp less?) output stage. joe |
#5 | |
Can you describe how the "sound" did change? I.e dynamics, soundstage, resolution.... Hm, i like to have the sound of "digital" away, i don't like hyper-detail or absolutely pinpoint imaging. But i adore an analog, engaging, dynamic sound. Would be great if the 825 help in that way? Problem is, like Extreme_Boky said, sometimes if you swap opamps the sound becomes too "clean" or un-involving. Of course this is a subjective thing, hm. |
#6 | |
![]() Regarding the digital and analogue PSU upgrades, can you tell me which ones you swapped exactly? On the PSU board http://www.beichel.at/x505es/power-board1.jpg there are two ELNA Duorex, the smaller ones are black [M] Matsushita/Panasonics and brown (Elna?) ones. Which caps (brand, specs) did you put in instead? And the caps around the DAC: Like C614 (the biggest one, right in the center http://www.beichel.at/x505es/audio-board1.jpg) is not a decoupling cap am i right? It is probably used as a electric buffer for smoothing out the power supply? So which ones are exactly the decoupling caps, can you tell me? Did you just swap them with sanyo os-cons with the same specs, or is more uF or so generally considered a good thing to do? Would be great if you had your 505 still around you, even if you are/were not that satisfied with its sound.I'm new to DIY-modding, so far i only installed a Lclock XO2 w/ PSU and I'm very pleased with the result, the sound's got much more dynamics, attack, liquid lows mids and highs. Even if these Sonys seem to have 2 clocks, some people say that the 16Mhz is derived (calculated: 1/3) frequency from the 45Mhz XO clock supply. And wow, NOW listening fatigue is completely gone, instead you will be foot-tapping all the time as the music's timing is so much better! Your help regarding the cap replacements is appreciated! Thanks.. |
#7 | |
The best result was using AD825 on Brown Dog adaptors for IC4/507 and the remainder left stock. The sound became very smooth, great detail and seemed to dig deeper in the bottom end. A more controlled natural sound without the tizz and boom excitement. Output caps C4/514 were changed to BG NX 47uF 6.3V and the by-pass C4/515 were removed. Power supply caps C508/C509 (I think) that fed IC4/507 were changed to Nichicon FG 47uF 50V. The supply caps C4/556 were changed to Panasonic FC. Everything else is stock except to Toslink changed to an electrical digital out. |
#8 |
The digital decoulpling caps around the dac are: C401, C403, C503, C408, C508, C630, you get the idea.
When it comes to digital decoupling the quality of the caps and short leads/tracks are more important than quantity. I think I replaced them with 100uF oscons because I had them at hand. It's probably worth to solder some 10-100nF smd caps diretly at the pins where possible. I can't remeber exactly what I did to the power supply. I probably replaced the caps with Panasonic FCs, apart from the main reservoir caps because I had nothing equivalent. I need to open the lid and have a look for more details. |
#9 |
I haven't touched the opamps yet but upgraded some caps in the analogue PSU to Pana FC w/ same values. The improvement is a smoother yet cleaner sound and lots more depth in the soundstage. Now i'm very happy since the total cost for these 4 caps was about 1,50 USD and yet the improvement is so easily heard!
Next i'll try to swap some digital decoupling caps, should I replace the caps using approx. the same values (ie 100uF/25V/50V etc) even if the voltage in the digital circuits is just 5 volts? One might think that it would be best to use something near the circuits voltage (thinking of 6.3, 10 or 16V). Dunno know why Sony uses such high volt caps, there could be a reason? The overall suggestion in digital decoupling seems to use low-ESR caps. According to Pana FC datasheet the 6.3V/100uF has imp. of 0.80Ù @100kHz, the 16V/100uF has 0.350 (less than half) 16V/220uF is again much lower: 0.117. The Ripple current is higher w/ higher volts & capacitance, is this a good thing here? So which caps could work best in digital decoupling application? * low-V (ie 6,3V) with higher esr * middle-V (ie 16 or 25V) with lower esr * low-V and higher capacitance (220uF or more instead of the 100uF) I tried hard to "extract" the answer from diyaudio's long and winding threads. Thank you. |
#10 |
While I agree that rolling the op-amps may bring improvements (with a bit of luck) the results are highly unpredictable though. Combining PSRR, CMRR, noise etc of the op-amp with a specific layout, power supply and application schematic hardly gives an indication about what was achieved.
I'd like to suggest a different approach: a closer look to the filter caracteristics (type, order, cutoff freq.) and optimize these first before spending money on 12 single op-amps and adaptors or 6 dual op-amps. Most likely the improvements will be quite noticeable and you'll have the chance to control/corelate the results to your liking... |
| Sony X505ES Fails | Hylle | Digital Source | 3 | 28th May 2009 08:57 PM |
| Opamp upgrade in Sony SCD 777es to AD8610? | PhopsonNY | Digital Source | 46 | 3rd May 2006 08:46 AM |
| Sony x55ES opamp replacements | 2Bak | Digital Source | 2 | 26th May 2004 09:25 PM |
| Opamp Mods for Sony DVP-NC555ES | emilo | Digital Source | 0 | 18th May 2004 07:48 PM |
| Sony SACD opamp upgrade with Ad8610 opamps? | PhopsonNY | Solid State | 8 | 3rd May 2002 04:49 PM |
| Page generated in 0.16390 seconds (85.81% PHP - 14.19% MySQL) with 11 queries |
