| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
#12 |
In newer Kenwood DP-8020 there is a head Sony KSS-152A
It is possible to replace a head just as in this device : |
#13 |
Vasiltech, thank you very much. I (and quite a few others) have been waiting and asking a long time, and you're the first person who's had any info.
Regards, Lee.
#14 |
Hello,
I thank you, too!! We would like to try to put in the Sony KSS which is a replacement type of the samsung laser unit. Do you have any further information about the wires and where they should be soldered? Do you have manuals or schematics of the laser units? Cheers Christian
Visit my DIY page at www.krishu.de |
#15 |
I cut out a part of the scheme with head Sony KSS-152A and RF Amp. CXA1081
With its help it is possible to understand where to solder. |
#16 |
Hello vasiltech,
thank you again, we will try and let you know when we succeed. Christian.
#17 |
Vasiltech,
thanks a lot for these informations. I still have questions: 1.) The Toshiba TOPH7833 is said to be compatibel to the KSS152A. Would that mean that even a KSS152A is worth a try? 2.) From the photos it's not completely clear (to me ...) what you did with the trimming potentiometer for the laser power. Did you leave the original Kenwood trim pot on the foil and remove the trimming potentiometer on the Samsung SOH-OT3? Cheers, Thomas |
#18 |
SOHOT3 is pin-compatible with sony KSS152???
Thanks for reply! |
#19 |
KENWOOD DP-8020:
To restore the head of KSS-152, I used as a donor KSS-150B, that is, its metal block on which the diode and matrix. Suspension from the lens and the focus and tracking coils leave home with KSS-152, otherwise it will not work. This optician (old style) it is difficult to find, but still possible. Applies, for example, inexpensive models SONY, and many other low-cost devices. There is a risk that does not work, but generally, the procedure ends successfully, the main thing that at the time of transplantation loop, not fallen off the matrix. And you must be sure that the donor worker. Several times did this reversal, and it works fine! Trimmer also put a donor! In KENWOOD DP-8020 did not have to make adjustments, it all fell like a native! Next in line SONY CDP-X333ES, but there will have to make a separate RF amplifier. Last edited by dimon68; 12th December 2011 at 12:30 AM. |
#20 |
Some time ago I was made succesfully replace original DLBA... for SOHOT3 (KSS152) in DP-X9010. Maybe is not pretty done but works dam good.
| Kenwood DP-X9010 and CD-R | Rien | Digital Source | 1 | 1st June 2009 07:33 AM |
| Kenwood KDC-M9021SE laser unit problem | lostsoul_msh | Car Audio | 0 | 2nd April 2009 06:31 PM |
| Kenwood DP-X9010 Transport issues | D.A.R.R.Y.L. | Digital Source | 15 | 21st November 2007 10:12 PM |
| Page generated in 0.10114 seconds (78.80% PHP - 21.20% MySQL) with 11 queries |
