AD1865 the best DAC - Page 6 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st December 2007, 07:43 PM   #51
Bernhard's Avatar
Originally posted by audiodesign
I have tested today a pair of LL7903 to increase the output level but the result was a bad sound.
The AD1865 since to be perfect with a caddock 200-250 ohm resistor and nothing else
I will try soon a ECC82/12AU7 stage after this passive I/V conv
did you terminate the secondary ?
if not, there will be ringing and it will sound ugly...
play a cd wth a square wave and watch it with a scope.
adjust with a 50kohm pot across sec. until ringing disappears.
Old 1st December 2007, 07:57 PM   #52
Bernhard's Avatar
Originally posted by robot
Sound with lundahl is very neutral across the whole audio spectrum but I feel that I miss some "action". Experiments with scope would probably solve problem of matching impedances which is crucial for the best ad output. Putting 5687 on the output of the dac changed sound and made it crispy, punchy with lot of detail, witihout any trace of treble harshness.
personally I am afraid tube output stages will always add some kind of coloration to the sound (?)
Old 1st December 2007, 08:06 PM   #53
Bernhard's Avatar
What are the best transformers ?
Lundahl, Malotki, Western Electric, UTC, Tango ?, what else ???
Old 1st December 2007, 09:16 PM   #54
robot is offline robot  Croatia
robot's Avatar
Any active component adds something to sound, that s obvious, but if I have to choose I prefer chain which consists of a few parts than a bunch of transistors, opamps and other stuff.... I wrote on other place rather poetically, that a dac with solid state output is electronic component, and with tube output is a musical instrument.
For example, I m using for sound comparing, and testings my friend s rather old combination of meridian 200/203 which uses very good SAA r2r dac, but it has infamous ne5534 opamps behind famous meridian digital stuff, and I think with a decent tube output would make this oldboy a killer dac.
Anyway I think that combination with a transformer on I/V than tube is very promissing in this case.
Considering best transformer, aren t Lundahls now in Jeff Rowland s gear?
Old 2nd December 2007, 07:49 PM   #55
Bernhard's Avatar
Recently I found a link to a website where big tubes are used for DAC outputstage but lost it...
Anybody knows the link ?
Old 2nd December 2007, 08:07 PM   #56
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
My test untin now are test:
1) only a 320ohm Caddock MK132 resistor connected to DACT 10k and to the amplifier
2) a 320ohm Caddock MK132 connected to LL7903 1:4 and to the DACT 50k and after to the amplifer
3) no resistor, connected to LL7903 1:8 and to the DACT 50k and after to the amplifer
case 1 play very good
case 2 play bad
case 3 play better but I not sure better than case 1
case 3 = audionote choice
Old 2nd December 2007, 09:23 PM   #57
robot's Avatar
There was a discussion a few years ago about this conception of I/V conversion on this forum, witihout any useful conclusion. Its obvious that audio note uses some transformer with silver wire behind dac very expensive indeed, but unknown specifications, so copying this witihout usage of their transformer is not effective, and probbably wasting time and money.
We all know about thorsten s try to copy an dac 4 signature, his adagio . It s obvious that he used I/V resistor, and some filtering before cf e182cc. Not an easy task I belive. I think the main difference between using transformer and tube output is lack of bass in first case, so combining those two approaches probably solves that problem.
Old 10th September 2009, 08:15 AM   #58
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Default Ad1865
case 2 play bad
Hi Audiodesign !
I design you cricuit DAC to layout,
The soud is very good, i like it, But I want output by tube not use tranformer. You can show for me exaple what tube can use for thi DAC!
Thank you very much
You can se my layout
Old 14th September 2009, 04:45 AM   #59
Im layout this DAC!
You can see here:
Old 18th September 2009, 06:14 AM   #60
Default Dac-end
Hi all !
I dont have tranformer, aloso I use I/V out put by tube, you can see my cricuit
THANK!
My DAC on AD1865 waldez Digital Line Level 1 21st April 2009 01:38 AM
My AD1865 nos dac purer Digital Source 10 6th July 2008 03:45 PM
AD1865 w/ USB? dsavitsk Digital Source 6 28th February 2006 10:47 AM
Wtb:- Ad1865 vt4c Swap Meet 1 26th March 2002 09:11 PM
Copyright 1999-2017 diyAudio
