Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th October 2010, 01:50 PM   #341
zeonrider's Avatar
Originally Posted by quanghao View Post
I think the power supply is not good, and all comment produce in China!
you change the supply for IV, the sound is better!
Ok.
Chinese
PSU not good
Change, with what, what is not god on Shunt regulators!
Those 2 trimers are in outpt stage!
Regards zeoN_Rider
Old 18th October 2010, 07:39 AM   #342
Moddang is offline Moddang  Thailand
Hi zeoN_Rider,
It look like series regulator???
Where you bought this DAC and how much? What is the website? Probably you may need to looking for the new DAC.
BR,
Moddang
Old 18th October 2010, 08:33 AM   #343
zeonrider's Avatar
Originally Posted by Moddang View Post
Hi zeoN_Rider,
BR,
Moddang
I changed for some goods
Regards zeoN_Rider
Old 23rd December 2010, 12:41 AM   #344
I recently purchased a DAC TDA1541A+WM8805 NOS 1.0UI multi-input from raindrop_hui on ebay. I cannot get any signal out from the analog out on the board. I have tried troubleshooting, but I am a novice when it comes to digital electronics. The communications is strained because of a language barrier and the most I've gotten from Mr. Zou is one email a day. I found some troubleshooting tips while scanning the site for Lesha's DAC. There is a voltage table of the TDA1541A pins posted on the site. According to it the voltage on pin 26 of the the DAC should read about - 5.1 volts. It reads -2.211 volts. I informed Mr. Zou of this and have not heard from him since.
Can you trace a digital signal with an oscope?
Old 22nd March 2011, 02:59 PM   #345
Cola is offline Cola  Singapore
With regards to Raindrop_hui 1865
I notice that the power transformer 18vac is converted to 15vdc and then to +5vdc/-5vdc while the transformer 9vac is comverted to 9.75vdc and then to 5vdc.
So is it ok to substitute the 9vac transformer with a 12vac transformer? And what is the purpose of the dual regulation when the 15vdc and 9.75vdc are not used at all?
Old 1st June 2011, 12:03 PM   #346
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Today I conneced my AD1865 DAC with LL1578XL on the output:
The gain is a little on the lowside,I have now a 200ohm resistor on the output
Will I get higher gain if I use a say,400 ohm resistor?
The sound is a little dark (donīt know how it is with the tube output?)
Old 1st June 2011, 05:42 PM   #347
Ryssen's Avatar
Quanghao do you have a I/V board,the one with the tubes on,Iīd like to buy one.
Or anyone else got a spare one.
Old 3rd January 2012, 09:26 PM   #348
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
Andrea,
What is the reason for using 200 ohm I/V resistor instead of recommended by AD 1,7 kohm?
Old 4th January 2012, 01:45 AM   #349
Yes, you will get 6dB higher output amplitude with 400 ohm I/V resistors. My experience is that the AD1865 will still produce excellent sound with a 400 ohm passive resistor I/V. This is a relatively rare ability, one shared by the PCM56. If, however, you are directly driving a transformer from the AD1865 outputs, the higher I/V resistor value effectively raises the source impedance as seen by the primary, not something to be desired in itself.
If this is a un-equalized NOS (digital filterless) design, then it might indeed sound a little dark, due to the well known -3.16dB @ 20kHz zero'th order hold response roll-off.
Ken
My DAC on AD1865 waldez Digital Line Level 1 21st April 2009 01:38 AM
My AD1865 nos dac purer Digital Source 10 6th July 2008 03:45 PM
AD1865 w/ USB? dsavitsk Digital Source 6 28th February 2006 10:47 AM
Wtb:- Ad1865 vt4c Swap Meet 1 26th March 2002 09:11 PM
Page generated in 0.09960 seconds (77.90% PHP - 22.10% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
