Deltec PDM 1.2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd October 2007, 06:16 AM   #1
Default Deltec PDM 1.2
Does anyone have the schematics for this little DAC?
It uses SAA7320 DAC chip and Sony CX23053 as DIR. Apparently it will not lock. So looks like the DIR is dead. Need to replace it with another DIR like CS4812, etc.
Old 23rd October 2007, 08:10 AM   #2
The receiver will be OK, it's the uA 9763(?) that will be dead.
This is (I think) an RS422 receiver used to buffer the SPDIF input and located next to digital input. Just replace it, the chip is 8-pin DIL and still available, cheap.
Buy a couple of spares actually, they seem very sensitive to ground currents - plugging my PDM1.2 into a cheap DVD player with a poor SMPS is enough to kill it.
Old 23rd October 2007, 03:39 PM   #3
Hi Martin,
Thanks for your info. I already replaced the receiver and it still wouldn't lock. : (
Old 23rd October 2007, 04:18 PM   #4
Have you checked the PSU rails and that the oscillator at the receiver runs when idle (no signal input)?
If you need I'm happy to open mine up and see what I can measure in the way of voltages and waveforms around the pins if that helps.
Old 24th October 2007, 05:34 AM   #5
JohnW is offline JohnW  Czech Republic
JohnW's Avatar
I've seen cases where when the UA9637 is damaged by input Earth leakage currents / Static it goes S/C between its PSU rails, this also burns out a small SMD resistor in series to supply pins to the UA9637. Check for 5V supply on the UA9637.
Coincidently, the reason the 9637 is damaged by Leakage currents is the fact that the construction of the RCA plug used for SPDIF connects the centre pin first (Signal) before Ground. This results in an "110Va Leakage loop" between the sensitive 9637 input and the SPDIF source. Units with SMPS such as Computers and DVD players are the worst offenders with larger earth leakage currents. Use optical if you can... Also, another reason where BNC is superior for SPDIF - not only can it be a true 75 Ohms interface, but also always insures Ground is connected BEFORE Signal.
If you still have no luck fixing the unit, I'm based in GZ - China and can repair your unit.
John
Time is my worst enemy!
Old 24th October 2007, 06:07 AM   #6
That's very kind of you. I will check those once i have time. many thanks
Deltec PDM 1.2 bertchai Digital Source 0 23rd October 2007 06:16 AM
deltec/DPA schematics dan _s Digital Source 6 8th August 2007 06:46 PM
Copyright 1999-2017 diyAudio
