| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm using a PCM1704 DAC with 8414 received. I have connected the PIN 14 of the PCM1704 directly to the ECC88 buffer stage...which is from AudioNote. I have attached the schema. When i turn on the digital signal to the DAC, i get a big "hiss" sound...with the actual music slightly in the back. When there is not digital signal coming in from the transport....the hiss sound disappears. Could this is a problem due to impedance. Can someone help me integrate the DAC and the tube buffer....any help would be great. Regards Sandy |
#2 |
Perhaps at 220K the i/v resistor is a little on the large side.
#3 |
See datasheet : http://www.datasheetcatalog.com/data.../PCM1704.shtml
This is a Iout DAC -> needs an I/V converter. The 220k resistor can't be an I/V converter, something is missing |
#4 |
Change the 220k to 50 to 100 ohm - IV resistor.
#5 | |
| ECC88 Help | rhysh | Tubes / Valves | 2 | 1st December 2008 10:52 PM |
| What to do with ECC88's? | Simpleton | Tubes / Valves | 15 | 16th June 2005 08:39 AM |
| PCM1704 + Pass D1 Output Stage? | OliverD | Digital Source | 4 | 10th March 2005 08:45 AM |
| OTL ECC88 amp | Tyimo | Tubes / Valves | 13 | 16th February 2005 04:40 PM |
| Page generated in 0.08273 seconds (65.05% PHP - 34.95% MySQL) with 11 queries |
