Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd October 2007, 02:15 AM   #31
maxlorenz's Avatar
Ah! that's better.
Cheapest horn speakers: https://picasaweb.google.com/lh/phot...eat=directlink
Old 25th October 2007, 03:29 AM   #32
anatech is offline anatech  Canada
anatech's Avatar
Hi rfbrw,
A little clearer then. All this talk of change is utter nonsense.
Well, considering that it seems that the experimenters have made zero effort to keep the rotating mass the same .......... Critical error !
The servos are tuned to the expected rotating mass of the system with a CD mounted. If you play with this, then you must retune the servo constants.
Re: rotating fields affecting the focus or tracking coils. No.
These are far enough away and shielded from the disc table by the metal in the head. If your head is plastic, stop. It's total scrap. Same if it has no bearing material for the rod and guide rail.
Anything at all that could possibly affect the sound will show up in the eye pattern. Any change will affect all frequencies equally, although the most annoying noises occur at the higher frequencies.
Can we put some of this silliness to bed now?
Hi Peter,
What do those transports look like? I mean when the view isn't blocked by large objects.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 1st January 2010, 04:57 PM   #33
tiefbassuebertr's Avatar
Originally Posted by poynton View Post
Could someone explain exactly how a magnetic clamping device affects reproduction as opposed to a non-magnetic clamp (eg brass) ?? Andy
We must distinguish between two other kinds of clamping:
1) Automatic disc clamping (with tray loader)
2) manual clamping disc with a heavy weight as a cd overlay (top loader version)
The last is clearly by far the best solution, because the error in reading about automatic disc clamping is also very much dependent on what material is the CD itself. Some CDs are mechanically resonant, so that sometimes a special sine wave sound from the CD player goes out (interchanging with the suspension of the collimator lens from optical pick up) Additional there are a wide range of different thickness and hole diameter. This means, you can sometimes hear different sound by the same compact disc between two performed loadings !!! Therefore I hate automatic disc clamping for loaders with tray.
For automatic disc clamping (with tray loader) the VRDS from Teac I would prefer most likely - go to
Teac VRDS 9 vs VRDS 9 by AM-Audio [English]
for an example
For manual clamping disc I would prefer the solution from CEC like this model because the use of heavy wight covering for cd and belt drive:
CEC CD TRANSPORT TL0X
By the way, a very good template for diy, because the actually mechanism could be the Sanyo SFP-101N
Audio Spare SFP101N15 (SFP 101N 15) - DA11 MECHANISM 15PIN...
JusTone Lasereinheiten. SF-P101-5/8 / SFP101-5/8 SANYO Lasereinheit, Laserpickup, Laserunit, Pickup, Laser, Laserkopf
Other versions are Bow Technologies (ZZ-8, ZZ eight)
Bow bought - whathifi.com - whathifi.com
and sakurasystems flatfish 4713
FLATFISH
Gluing and Clamping wintermute Construction Tips 6 25th August 2009 03:09 AM
lossless clamping with current sense, how? zilog Power Supplies 5 25th July 2008 11:59 AM
Disk Needs Help Spinning delory Digital Source 4 14th September 2007 07:37 PM
Output clamping diodes:When do we need them??? Leolabs Solid State 13 8th February 2007 06:58 PM
Page generated in 0.08714 seconds (71.43% PHP - 28.57% MySQL) with 11 queries
