Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Right voltage output using TCXO
Old 9th October 2007, 07:41 PM   #1
stef1777 is offline stef1777  France
Default Right voltage output using TCXO
Hi Folk!
I've a question for clock's masters.
I've a TCXO with an output of 1.71v. I want to connect it to a device to replace a regular cristal. I've enclosed the scope signal if this can help.
What is the right resistor value to insert to have the right output voltage? In fact, I don't know what should be the right voltage.
Unfortunaly, I don't have the device schematic but the first chip in in the circuit is an HCU04.
Stephane
Old 9th October 2007, 08:54 PM   #2
Sorry wrong screen shot.
Old 10th October 2007, 08:36 PM   #3
mkliu is offline mkliu  Hong Kong
hello,
I am playing around with my VRDS-10 and moving onto mod the clock part. Can you do me a favour that forward the schematic to my mail box 8888po@gmail.com Merci!
Old 10th October 2007, 08:49 PM   #4
Originally posted by mkliu
hello,
I've to look in my archives.
Old 10th October 2007, 08:50 PM   #5
And the schematic for the question at the botton if someone have the answer. ;-)
Old 11th October 2007, 01:36 AM   #6
yygomez is offline yygomez  United States
Send a message via AIM to yygomez Send a message via MSN to yygomez Send a message via Yahoo to yygomez
Hi Stephane,
Remove C69, C60, and Q3. feed the output of your TCXO to pin1 trough a 0,01uf cap capacitor. That should do it.
please note tha you have to keep the bias resistor r48 ( do not remove).
Jorge
JG
Old 11th October 2007, 02:21 AM   #7
Great Thanks and very much appeciated your help!
Old 11th October 2007, 06:19 AM   #8
Originally posted by yygomez
Hi Stephane,
Jorge
Curently, I've connected the TCXO using an 47R resistor and it work. What is the advantage to use an smal caps instead?
mkliu, I'v sent the files.
Old 11th October 2007, 03:37 PM   #9
in short answer, Your TCXO is 3.3v, the circuit is 5v. With the cap and the R48 1M biasing the 74HCU04 the circuit is going to trigger on the steepest part of the TCXO waveform which means less jitter.
JG
Old 12th October 2007, 04:30 PM   #10
Got the file, it's very useful.....I just start putign a new TXCO in my vrds10.....
Right voltage output using TCXOHide this!Advertise here!
Citypulse 7.2X II DAC with TCXO chamcal Digital Source 0 19th February 2008 07:42 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Where can I buy TCXO ackcheng Digital Source 0 21st February 2005 04:04 PM
Tcxo XTAL Digital Source 21 17th May 2004 01:18 AM
Tcxo XTAL Parts 0 11th May 2004 09:21 AM
Copyright ©1999-2017 diyAudio
