| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have just soldered the digital connections to my PCM2702 but when I hook it up to my computers, all I get is "unknown device". What could be wrong? Am I correct when I assume you can just test the DAC with no analogue power supply?
#2 |
No. Even if you are not using the analogue stage, you still must supply it for the device to function.
#3 | |
Ahhhh. thank you. then all hope is not lost. I will give it another go today. |
#4 |
hmm.. still doesn't work. there doesn't seem to be many problems with this chip. almost every forum thread is just beautiful pictures from guys who made it work right away. i can not figure out what i've done wrong. apart from a bit fewer caps on the analog power supply side i have done exactly as the specs sheet suggest.
#5 |
I connected it to my linux (ubuntu 7.04) and now it works great
| Another PCM2702 DAC project. | Dxvideo | Digital Line Level | 1 | 4th March 2009 07:05 AM |
| My USB audio DAC (PCM2702) | veteran | Digital Source | 8 | 17th August 2006 08:33 PM |
| Is anybody can help me with my PCM2702 | burderly | Digital Source | 4 | 5th August 2006 03:51 PM |
| Pcm2702 Usb-dac | 00940 | Digital Source | 47 | 24th January 2005 04:36 PM |
| Pcm2702 Usb Dac | sugano | Digital Source | 9 | 27th May 2003 06:37 AM |
