Problems with LM4562 Opamp in Tjoeb '99 cd-player - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th November 2007, 09:49 PM   #11
Bassivus's Avatar
Don't use ceramic caps here!
Old 19th November 2007, 09:55 PM   #12
Please explain your comment.
Jon
Old 19th November 2007, 10:10 PM   #13
Bassivus's Avatar
I know it works, I just don't like ceramic caps anywhere near analog signal path. It usually makes the sound hard, metallic, and can induce microphony.
Old 19th November 2007, 10:22 PM   #14
You want something with good HF properties (low ESR at HF and low ESL) so a surface mount ceramic would be better than a leaded film cap in this respect.
What about a combination, ceramics from + and - to GND and poly between + and - ?
Jon
Old 19th November 2007, 10:23 PM   #15
BrianDonegan's Avatar
Use C0G/NP0 caps and you will be fine.
Old 19th November 2007, 10:29 PM   #16
Bassivus's Avatar
I agree, those are better...
Old 19th November 2007, 10:57 PM   #17
Ceramic caps on the power supply pins are the preferred caps to use. They will snuff out any RF oscillation as was previous stated. Also use some nice Panasonic FC caps. low ESR, as bypasses for PS pins.
Ceramic caps as SIGNAL caps are to be avoided at all costs. This is probably what you might have heard about ceramics.
Regards, Marcus
Old 19th November 2007, 11:07 PM   #18
Bassivus's Avatar
Regards, Marcus
Hello, Marcus - jrockhead and welcome
I've beliveve only what I have heard with my two ears
Regards, Ivica
Old 19th November 2007, 11:16 PM   #19
I haven't soldered a ceramic capacitor (0,001uF) right across the power supply leads but soldered it underneath an 8 pin dip socket in wich i put the opamp itself. Could this have a bad influence on the functioning of the the capacitor?
To decouple HF you need low inductance - a cap with short (preferably no) leads. So solder the cap directly across the pins, the dip socket pin effectively extends the lead of the cap and increases the inductance.
What else can be done? If i use a 0,01uF cap instead of the 0,001uF, could it make a difference?
Use 0.1uF (100nF).
Old 19th November 2007, 11:31 PM   #20
jan.didden's Avatar
To decouple a supply you need caps with'*some* esr. The idea of 'damping' is to take energy from the system to prevent it from ringing or oscillating. You can't do that with pure C (or L, for that matter).
Using audiophile (read: almost zero esr) caps for supply decoupling may even make the problem worse. Those ceramics with their losses are excellent for the purpose. If you read data sheets for low-drop-out regs (where you need the same caps to prevent oscillation) they even specify a MINIMUM esr, certainly not the lowest possible.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
qed digit opamp problems little blue Digital Line Level 49 16th February 2014 07:56 AM
headphone amp with lm4562 opamp umut1001 Headphone Systems 23 15th April 2008 03:08 AM
AH Njoe Tjoeb CD player, valve Compatibility emperor Digital Source 0 13th November 2007 06:15 PM
Njoe Tjoeb 4000 vs RESPONSE AUDIO Signature CD-25 Tube Modified HDCD Player scientist1 Digital Source 1 5th January 2004 09:13 AM
preamp opamp problems jnxw2 Solid State 7 27th May 2003 02:26 AM
Copyright 1999-2017 diyAudio
