Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Question about Marantz 65 II SE mod
Old 24th September 2007, 08:22 AM   #1
an1id is offline an1id  Bulgaria
Send a message via ICQ to an1id
Default Question about Marantz 65 II SE mod
Hello Gays ,
I have this player Marantz 65 II SE and I want to optimise it for The better Sound. All information about this player are wellcome.
Thanks in advance !
Old 24th September 2007, 03:30 PM   #2
hifimaker is offline hifimaker  United States
hifimaker's Avatar
In all seriousness - I get a small laugh out the all the money people spend on modding the CD63,65,67 CD players. They were nice for there day as a low cost hifi player.
This is not intended to make anyone angry who loves to spend hours diying the Marantz CD players for fun.
The best mod a person can make is to get a external DAC and feed it with a TOS connection from this CD player. Some people prefer SPDIF, I'd rather isolate the ground from a cheap CD player from my DAC.
Search this forum for the "Which DAC" thread. There's lots of great ideas for buying manufactureres DAC eval boards and building your own highend DAC on the cheap.
In the end you will be light years in sound quality ahead of spending any money on the internals of the Marantz.
Just use the Marantz as a transport. You can then even use your PC as a transport which is even better!
Good luck,
-David
Old 25th September 2007, 01:28 PM   #3
philpoole is offline philpoole  England
Modding a Marantz (or any player) does have the distinct advantage of not converting the digital signal too and from SPDIF. Everything stays I2S - which is much better.
Besides, SPDIF is selfclocking and can introduce of jitter.
Having said that, I use a seperate DAC these days, but feed it balanced I2S using RS423, which works quite well.
And, I think modding a player is a great place to start learning.
Phil
Old 27th September 2007, 07:15 AM   #4
sinigersky is offline sinigersky  Germany
sinigersky's Avatar
SPDIF is a "flawed" interface, because it puts jitter noise to the DAC clock.
http://www.scalatech.co.uk/papers/aes93.pdf
It is far better to install a low jitter clock next to the DAC inside the player, which will also control the transport. An external DAC would not have the master clock and will be prone to jitter induced by the digital signal line.
The right way to do it would be to use the external DAC clock in the transport, see for example
http://www.burmester.de/produktlinie...ence-line.html
...or use a PLL-locked reclocking, which has some limitations, see
http://members.chello.nl/~m.heijlige...tml/dactop.htm
I would recommend you to start with installing a low jitter clock in your Marantz - this will be very satisfactory and is a major upgrade.
GeleTheMaster / SINIGERSKY AUDIO
Question about Marantz 65 II SE modHide this!Advertise here!
Marantz Troubleshoot Question stvnharr Digital Source 0 14th April 2009 04:21 AM
marantz question sadim1223 Solid State 1 24th February 2009 04:38 PM
Marantz PM-32 question AdrianW Solid State 8 28th May 2007 02:14 PM
Marantz CD75mkII to mod or not to mod that is the question. El_Hefty Digital Source 6 31st August 2006 01:29 PM
little Marantz CD-80 question jordanism Digital Source 7 30th August 2005 02:29 AM
Copyright ©1999-2017 diyAudio
