Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th October 2007, 11:49 AM   #21
Algar_emi's Avatar
The transfo I used are perfectly stable, really overspec for the application. I measured very low supply currents on all supply sections (typically <40 ma, most of the time a lot less). The transfo I used are rated 0.8 and 1.0A per secondary, plenty of current available. All DAC supplies are perfectly stables. I got 7.9Vac and 19.5Vac respectively at the DAC inputs
The final version 2.0 is using:
8Vac: 110-220V Prim, Dual 8Vac, 0.5A each, 6VA, Digikey MT2103-ND
16Vac: 110-220V Prim, Dual 14Vac, 0.42A each, 12VA, Digikey MT2120-ND
The first version was using for the 8Vac, the MT2107-ND, Dual 8Vac, 0.4A each, 6VA that was producing about 10Vac. It was working just fine with all the supplies connected to the 8Vac input connectors. The final version gives a nice 7.9Vac which is closer to the needed value.
Take note that the PCB ver 2.0 has the supplementary 8Vac output, for a total of 6 X 8Vac outputs to support the upcoming new AYA DAC version (Pedja suggestion).
Here picture of the ver 2.0 PCB assembled
Old 19th October 2007, 03:15 PM   #22
Kip is offline Kip  United States
Hi Algar_emi,
I haven't started to assemble my AYA dac ver. 2 yet. I don't see any info on the site about a ver. 3. I am wondering if I should wait. Can't I use the parts purchased for the ver. 2 in the ver. 3?
Old 19th October 2007, 03:52 PM   #23
Algar_emi's Avatar
Yes indeed. Pedja asked me to add a 6th 8Vac output to support the new upcoming AYA DAC. So you're covered. There is also a 4th 16Vac output available directly on the T5 transfo if the need arise.
Old 19th October 2007, 03:53 PM   #24
Algar_emi's Avatar
All PCB kits are ready to go and include detailed assembly instructions, schematics and parts list. Have fun.
Old 12th November 2007, 05:06 PM   #25
Algar_emi's Avatar
Here my own AYA DAC ver 2.0.
Leds on the front are Power On, Lock, and the two digital inputs IN1: Passive, IN2: Active. Two switches, Power-On and Input Selection.
On the back, two Cardas RCA audio out and the two real 75 ohms BNC digital inputs.
Old 12th November 2007, 05:12 PM   #26
Algar_emi's Avatar
Here the inside view. I built an separate enclosure to insulate the transfo PCB (this is version 1.0). I routed the AC supply voltages using twisted pairs.
Old 16th November 2007, 07:55 PM   #27
eboz is offline eboz  United States
Send a message via Yahoo to eboz
Looks awesome! I am really looking forward to building mine. Just one question though. How does it sound compared to your other DACs??? What are your thoughts? I purchased this DAC based strictly on its engineering merit
Old 4th January 2010, 09:57 PM   #28
Algar_emi's Avatar
Worked a little bit today on my Aya. I had an unused pair of nice Jupiter 0.47uF caps that I got from an other project. I used it as bypass caps for a very standard 4.7uF Solen caps. I want to try other coupling caps than the BG 4.7uF, type NX I used to have into the Aya. They may be the limiting factor of the nice dac.
Old 5th January 2010, 10:32 PM   #29
Algar_emi's Avatar
Indeed with these new coupling caps, the DAC just sings. I like this sound much better than with the small BG caps.
FS/FT Shure & UE Accessories cyberspyder Swap Meet 4 19th August 2008 02:29 PM
Chassis and accessories for UCD patriz Vendor's Bazaar 5 18th December 2006 09:46 AM
Arm lift and other accessories AuroraB Analogue Source 1 19th August 2003 11:55 AM
Page generated in 0.09660 seconds (75.26% PHP - 24.74% MySQL) with 11 queries
