Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th September 2007, 12:26 PM   #1
wmincy is offline wmincy  Malaysia
Default Pioneer laser calibration
Hello Guys,
I've just got a Pioneer PD9300 cd player. As i opened the case, i found the laser lens was dropped out from where it should be. Then I remove the black plastic cover of the laser unit in order to work freely on the lens. I glued it up with some drop of Vinavil. After replaced everything, I put a CD on, but the laser couldn't find the track... the red beam is visible, so the laser was working, I just guessed if it was a problem of calibration. Is there anybody can help me to fix this stuff? there are 6 VRs to make the calibration (tracking, focus, rf). Please heeelppp.... Thank you.
the fever of DIY HI-FI will NEVER be cured !!!!
Old 20th September 2007, 04:29 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Don't turn the pots without equipment, experience and a manual.
Pioneers are though to adjust. I would think that some other problem is the cause here. (Glue on the lens?)
I would advice you to bring it to a good Pioneer service station.
/Hugo
Old 20th September 2007, 04:44 PM   #3
many thanks to the one who did provide me service manual of a PD8500, different schematic but the laser unit is the same.
Yes Netlist, thanks for your advice, i made a mark on each of the six VRs so i can back-up. Actually i glued the lens, just like it was before.
The problem was solve that was not due to the calibration, but simply adjusting laser unit (radial and tangential adjustment, and "grating hole"). Now the player is running smooth and silence.
What a relief....
Old 20th September 2007, 04:46 PM   #4
Netlist's Avatar
You are a good repairman.
/Hugo
LASER for Pioneer PD-S06 trane Digital Source 2 16th June 2008 04:20 PM
CLICKING Sound when spinning CDs on Pioneer DV-575A ,HELP...laser or what??? stifa Digital Source 6 24th November 2007 01:07 AM
Pioneer PD-S705 and PD-S904 laser type PAteam Digital Source 6 9th May 2007 02:47 PM
pioneer dv-444 dvd laser part number fender62 Digital Source 1 27th February 2007 09:58 PM
CD Laser Pickup Calibration bordins Digital Source 0 27th April 2006 02:26 AM
Page generated in 0.07652 seconds (69.45% PHP - 30.55% MySQL) with 11 queries
