Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd September 2007, 07:18 PM   #41
Eric Juaneda's Avatar
Hi Sy,
Originally posted by SY
Dither is necessary to avoid both amplitude and time quantization error. It converts errors of time and amplitude resolution to errors of noise. For example, if you have an undithered sine wave that drops in amplitude, at a certain point (at the LSB) the sine wave suddenly vanishes. With dither, you hear a little more hiss than before, but you can hear the sine wave even as it drops below the supposed resolution limit of the system- sort of like analog tape.
Ok, dither introduce noise out of audio band and shift digital noise higher.
Eric
Old 23rd September 2007, 07:44 PM   #42
Originally posted by Eric Juaneda
I never understand why CD are not recorded to 0db, since recording studio works with 24bit resolution?
Eric
Like the later recordings here ? Recording levels are more a function of competence than sample rate and wordlength.
Old 23rd September 2007, 08:41 PM   #43
Thanks guys for allr your good links, very interesting and the dac simulator is very pedagogic.
Lower closed loop gain? Higher slew rate. fotios Solid State 4 27th July 2009 01:41 AM
Computer coax digital spdif output.. USB?... Sampling rate?? dqswim Digital Source 13 12th November 2005 03:40 PM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 04:28 PM
AD1890 sampling rate converter problem nFORCE Digital Source 1 25th November 2002 03:53 PM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 04:01 AM
Page generated in 0.06552 seconds (80.06% PHP - 19.94% MySQL) with 11 queries
