| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Thread Tools |
I saw that in the february issue of the magazine audioXpress is a review or article on the Behringer Ultracurve DSP8024. http://www.audioxpress.com/ I'm very interrested in that story. Can sombody tell me something about it (what are their findings, are there any tweaks or recommendations?). I have an Ultracurve myself. I'm thinking of getting an subscription on that magazine, but living in Holland, it is always a bit of a problem. Does anybody know the mag and what do yo think of it???
Is that all there is? |
#2 |
The story was mostly posative. The biggest difficulty is that the unit does so many things that it can take some time learn to operate it correctly. (Since I have one, I can confirm that.) For home use the primary featute is Auto-Q which performs automatic room equalization. It claims thoi noise level is lower than an analog unit performing similar functions.
One of the difficult parts is that the lowest THD+N performance occurs when inpuyt levels are increased to just below the level at which clipping occurs. There is a red light light that comes on when digital clipping starts. If you use the slider control to reduce the output level then you will compensate by setting the volume level on you preamp higher, thus increasing the level of the input signal. So far I have stayed well below the clipping point so I'm not getting the lowest THD+N, but I cannot hear it so I'm not motivated to push it to the limit. Anyway the price is very low for the performance and features. |
#3 |
The 8024 is fairly good, it is best used in the digital domain.
Even with a great external dac, it is not 100% transparent. With a couple of external resistors it can be made to work with spdif i believe (using aes/ebu here) The price is very low these days. It needs a fireware upgrade to be able to do the auto eq. (v1.3 or greater i believe) Even when used in the digital domain power supply mods can be easily heard. **** off the standard diodes for schottky's or hyper fasts. Bypass things with ceramics in the ps as well. The digital eq market is really starting to hot up. It would be handy if Behringer released a eq box that could handle a dollby digital ac-3 stream. don't even consider an old second hand Ultra curve 8000, its a pile of crap. Mark Hathaway |
#4 |
Okay, thanks for the replies.
I'm planning to use it connected to the s/pdif (of a Sony SACD player). I have bought an s/dif - AES/EBU converter for that (M-Audio CO3). Of course I will only be able to process normal CDs. SACDs will go straight to the pre. Still have to upgrade the software to v1.3. I understood that the automatic roomcorrectionmode is not using all the features (it is supposed to only use the equalizer, not the parametric equalizer). Sombody I know from the web does the corrections manually using some measurement software on his PC. (eg http://www.siasoft.com/index.shtml or http://www.speakerworkshop.com/ ) From some comments on an Dutch hifi forum I understood it is possible to upgrade the soundquality of the behringer (to the level of the Tact) The supossed mods are: - replacing the trafo by a torodial Amplimo or such - seperate "buffering" for analog and digital sections - different outputstage (eg. opamp opc275) - replacing elcos with eg Elna of other - removing the sevo balanced stage (??) section and replacing it with a Jensen "scheidngs" (sepration??) trafo (Dont know how to translate some words )Any comments on this??
#5 | |
Behringer Ultracurve Review After the Mods described in the review I added Stevens & Billington Line Output Transformers (these are second source versions of the Jensen Line Outs) as shown and described here: Audio Asylum - Behringer blood & guts pictures You may also find my writings on how to use and digitally interface the UC helpfull: The Dossier - pointing and shooting the Behringer I suppose replacing the mains transformer will help, but I suspect my PSU upgrades with schottky diodes and better regulators may give a larger sonic upgrade. As I never had a TACT in my system I could not say if a Behringer Ultracurve 8024 modified as I suggest will equal the sonics of the TACT. Nor has the UC quite the same correction ability as the TACT has. On occasions where I heard the TACT in other systems I did however that if the UC is used correctly and with sense the results in correcting room/speaker deficiencies where not that different and both TACT and Behringer tend to bring huge improvements. My OWN modified Behringer EQ appears in my system subjectively as transparent as any box of tricks can get, it is no worse than a really good solid state preamp or buffer, assuming the levels are set suitably (high). I repeatedly had the chance to demonstrate this to (audiophile) guests as well, so it is NOT just my imagination. Sayonara |
#6 |
What about changing the 11.289 MHz clock crystal for a low jitter clock module ? Sampling with low jitter must make a difference.
This was my plan only Behringer doesn't give or sell manuals because of Intellectual Property. Wanted to do it the right way and I prefer to do it with a manual at hand. Since I don't have a schematic I think I have to do it the hard way. Regards, jean-paul
It's only audio |
#7 | |
I have a subscription from, oh, 1979 I think, never missed an issue, no problems. Recommended. Jan Didden |
#8 | |
Sayonara |
#9 |
Wauw, lots of information here, thanks again everybody. Good reading stuff.
One thing I dont understand. Mr Wang are you the same person as mr Thorsten?? Anyway nice pictures of your set. Also interresting speakers (Tannoy I believe). Did you make those yourself? Guess I have to get that subscription to audioXpress.
#10 | |
Plus RF decoupling with ferrite beads and a metal case for the module are some of the ingredients to success. Especially the 45.1584 MHz modules are hard to tame. Unshielded you'll find this frequency at almost every spot in the device ! Feeding it with the power supply in the device itself is almost always a guarantee for ground "problems". Despite that I never had a player that became worse or stayed the same. What module did you use ? How did you find jitter became worse ? Jean-Paul
It's only audio |
| Thread Tools | |
| Behringer DEQ24/94 UltraCurve Pro $200 | Zero Cool | Swap Meet | 1 | 19th March 2007 11:09 PM |
| FS: Behringer DEQ2496 UltraCurve Pro | Rescue Toaster | Swap Meet | 3 | 4th February 2006 01:38 AM |
| Behringer Ultracurve DEQ2496 - ways to use it? | paulspencer | Multi-Way | 28 | 25th December 2004 11:56 AM |
| For Sale: Behringer Ultracurve w/digital I/O | Bill F. | Swap Meet | 13 | 9th February 2004 03:23 PM |
| Behringer UltraCurve Pro DEQ 24/96 | Intelonetwo | Swap Meet | 5 | 7th October 2003 06:21 AM |
| Page generated in 0.11739898 seconds (87.51% PHP - 12.49% MySQL) with 10 queries |
