| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Will they ever stop?
Witness the new AK4397 32 bit, 196kHz DAC. Phase-perfect digital filter, fully differential analog out without the need for coupling caps, digital level control (32 bits, remeber). Direct interface to 32-bit path outputs from DSP's. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#2 | |
giulio |
#3 | |
Jan, one techincal query, when designing a 2 pole low pass filter, how critical are the real values used when compared to calculated values, that will affect the cutoff frequencies, and more importantly the phase. this is most critical when one is using discrete comps rather laser trim SMDs. any comments, I think you have some experience in this area. |
#4 | |
Not sure that that gains you all that much. The actual increments or decrements still have to be of a practical size. |
#5 |
I just received an AKM4397 eval board. I'm hoping to have it hooked up within a week. I'll let folks know how it sounds.
It does include the new National LME49710NA opamps for the active filter. -David |
#6 |
Hi David,
I'm curious about all the new DACs. I'd look forward to your opinion about this one. I've read some of your other posts with interest. It's good to hear that someone actually likes the sound of some of the new DACs. I would hope that some of the new digital technology actually sounds as good or better than non-oversampling DACs. Especially, since I don't know of any non-oversampling DACs for Hi-Rez audio. I can't quite imagine a multichannel home theater processor made with those old old technology DACs. My hope is that in the future, there's will be a multi-channel processor project here, which will decode and convert every conceiveable format including SACD, DVD-Audio, PCM, 16/24/32 bit 44.1-192KHZ , LPCM, MLP, Dolby True HD, DTS HD Master etc. Will have every conceivable input. SPDIF, optical, HDMI, USB ETC. . . Have tube and transistor output stages. Be modular. And anything else I've forgotten to include. This way one project could be built and improved upon by anyone looking make a DAC project. To me this would be better than everyone building many different projects. |
#7 | |
#8 | |
Jan Didden
#9 | |
Jan Didden
#10 | |
Well one option would be to take a Behringer DCX2496 dig xover with a 32bit DSP path and interface it directly with this DAC. Jan Didden
| Page generated in 0.09610 seconds (89.23% PHP - 10.77% MySQL) with 9 queries |
