| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
How good is it soundwise? Especially it's Voltage Out? I am considering buying an old cd player with this chip and use its voltage out directly for sound (feed it to a 10k stepped attenuator).
Thank you! |
#2 |
PCM54 is like most other multibit DACs, 10% of them are good.
I think it has Iout so passive I/V or external I/V with modern opamp is possible. The player should have a pair and not only one... |
#3 |
So using the Vout directly is not as good as using the Iout with modern op amps -- It makes sense since op amp inside the chip is not comparable to the modern ones.
As for a passive I/V, with regard to PCM54, what value of resistor should I use? Thank you! |
#4 |
Also, would I need a buffer inbetween this passive i/v stage and my 10k stepped attenuator (is the voltage after the i/v stage strong enough, with regard to PCM54)? Thanks again!
#5 | |
You could use a pot and check for distortion. |
#6 | |
| Good general purpose opamp with good DC specs? | speakerguy79 | Parts | 1 | 17th November 2006 04:10 AM |
| Any PCM54/55 type chips and R2R ladders out there ? | percy | Digital Source | 8 | 3rd November 2006 01:57 AM |
| Good switch for Stepped attentuater, Good cheap RCA jacks | pjpoes | Parts | 20 | 10th March 2005 08:47 PM |
| Page generated in 0.08572 seconds (72.11% PHP - 27.89% MySQL) with 10 queries |
