Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Voltage-out DAC without an output filter
Old 16th September 2007, 06:51 PM   #1
mudihan is offline mudihan  United States
Default Voltage-out DAC without an output filter
As a purist approach, one can connect the outputs of DACs with voltage out (such as TI's PCM1753) directly to the next stage (a preamp, a volume control, or a power amp). I was reading this article:
focus.ti.com/lit/an/sbaa055/sbaa055.pdf
and it talked adding an output filter (P6). Two of them are active, so I am not considering them. But the first one, the 1st order passive filter, involves only a resistor in series and a cap parallel. Is such a passive filter necessary? What are the advantages and disadvantages of using/not using such filter?
Since I am using a 10k stepped attenuator, I do not want the source output impedance to be to high (may change the attenuation curve).
Thanks!
Old 16th September 2007, 07:56 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Red Book CD performance specs include the filtering to obtain the specified signalk to noise ratio. How much you have to filter depends on the sampling rate of your DAC. With a high sampling rate, the sampling noise is at a higher frequency so you can maybe get away with a simple RC filter.
Otherwise you need more steep filtering, either active or poassive L-C sections. You probably should research this a bit more.
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 17th September 2007, 11:20 PM   #3
ttan98 is offline ttan98  Australia
I use a single low pass filter after the I/V amp., and then a buffer, it seems to work very well.
I think if you pick the correct I/V amp and buffer combo, it will sound very good.
I think the THS4031 used as I/V is ideal and LT1010 as buffer. Others think 4031 and buf such as BUF634 or OPA627(expensive) or AD825 are also applicable.
2 poles low pass filter need to use accurate and or non preferred values of capacitors, they are sometimes hard to get or matched esp. those that come from discrete comp not so much as from SMD cap. Jan may shed some light on this.
Old 18th September 2007, 12:29 AM   #4
Extreme_Boky is offline Extreme_Boky
Default Re: Voltage-out DAC without an output filter
Thanks!
I don't us any filtering at the DAC output, in particular if it is current out. Later on yes, but not at the I out.
In your case (V out) I suppose you can always check the amount and spectrum of digital rubbish you are getting, and act accordingly. Your amplification may be more sensitive to this rubbish, and could cause some overheating (in extreme cases) - but this can be tested as well: load the output with capacitive load (worst case) and check the amp for stability - see what comes thru to the speaker's end and how the amplifier handles this with difficult loads (donít forget that the speaker cables if capacitive, will make things even worse!)...
(Scared enough?)
Good luck,
Boky
Old 18th September 2007, 03:20 PM   #5
hifimaker is offline hifimaker  United States
hifimaker's Avatar
A couple of factors to consider...
1) Delta Sigma DAC's create a lot of high frequency noise that your tweeters must deal with, and a resulting loss of the contextual dynamics due to the the noise.
2) No active filtering will result in drive problems with the preamp. The DAC to preamp connection becomes VERY dependant on cables. With the right active filter design, much less exotic cabling is needed.
Just my own experience.
-David
Voltage-out DAC without an output filterHide this!Advertise here!
Filter Capacitor & correct voltage jomatecc Parts 3 28th October 2008 01:27 PM
filter choke voltage rating nhuwar Power Supplies 3 28th October 2008 02:45 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Voltage controlled filter with tubes ?? jim Tubes / Valves 3 28th September 2005 10:18 PM
