| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
i know it`s a stupid question... Has anyone experiences about sound quality diferences between using a very good soundcard with very good DACs, connecting analog to very good AMP and comparing this wit the Spdif output of a very good souncard, connecting digitaly to a real digital amp like Tact or Panasonic Sa-XR series. theoretically the digital connection should be better, because a DAC is not needed... Thank you. Ralf |
#2 |
Being a little facetious, I'll ask "is there such a thing as a very good real digital amplifier"?
Secondly, there must be a DAC somewhere in the reproduction chain.
regards Andrew T. |
#3 | |
Hi, i own several Class A amplifiers like JLH, AlephX, Hiraga Monstre and Tube amps. but none of them beats my modified panasonic. i think i know what i say:- there are very good digital amplifiers... the question is: where are the advantages in having a DAC or going fully digital. Ralf |
#4 |
Sorry, but it seems to me that you are comparing things that are too different. The point is not the analog vs digital link, but whole different chains.
It's the soundcard's converter amplified by, say, your JLH compared with the "digital amplifier's" converter amplified by his own local private final stages Then you can still compare, but it would be a specific brand and model with a specific brand and model. No? _ |
#5 |
It CAN make a big difference...
I've made the comparison using TI amp in the picture and some speakers with 6-1/2" Usher woofer and Usher tweeter. The amp is one of the TI evaluation boards that has a TAS3004 audio processor, which I used for an 8-pole digital crossover. I compared the all-digital chain from SPDIF through the digital amp with the analog output of a decent Pioneer CD/DVD/SACD player going through the analog capture in the TAS3004 chip. It's easy to do with the TI DCT tools--just change the input of the TAS3004 from digital to analog. There is a very easy-to-hear difference, and the all-digital path is noticeably clearer and sounds more dynamic. I had someone else listening who was rather impressed by the difference. Now, if the A-to-D in the TAS3004 were higher quality, or if the DAC in the CD player was higher quality, maybe the difference wouldn't be as great. But yes, there can be a big difference.
#6 |
thank you for the information.
does anyone know if there are digital amps with digital input availlable? Ralf |
#7 | |
A couple of years ago, RCA had some very affordable home theater amps based on the STA500 series (DDX). An oddball that should be fun to play with is the 6-channel DDX amp in the Spherex X-Box surround system (I've got a couple at home that I need to dig into). As far as I know, the digital amps are all multi-channel "home theater" amps--that is, I don't think there are any stereo or monoblock amps that use a pure digital amp. The only stereo or monoblock digital amps that I know of use analog feedback to control the digital output stage and they have an analog input. Tripath (RIP), B&O (ICE), Hypex, Coldpower, Philips...these are all "class D" or variants that have analog inputs. Keep in mind that the digital amps are essentially high-powered DAC's, and they require a good regulated power supply. In fact, TI has an app note that discusses the relationship of distortion at low frequencies as a function of the length of wire between the amp and the power supply. So you need to make sure the design is implemented properly. Also, the output filters are designed for a specific load impedance and the amps may not perform well for different loads. As I tried to indicate, I'm not sure that I've characterized the market adequately--if someone else has more recent or more accurate info--please speak up. |
#8 |
are you saying there are a few digital amplifiers that do not use a DAC between them and the signal? If this is the case then it would appear that the switching amp is varying it's rate and/or duty cycle on the digital values coming from the data stream. Without the use of any analogue conversion in the process? Any ideas on how they are achieving this?
regards Andrew T. |
#9 | |
TI and Apogee have had pure digital amps for quite a while. Totally DAC-free, although some argue that the amplifier itself is actually a power-DAC. Do a search on Google for "TI, Purepath" and "Apogee, DDX" for more information. Both companies have lots of app notes and datasheets available. Apogee sold their amplifier products to Sigmatel and ST makes the chips. Here's a blurb from the old Apogee website that references their amplifier products: "The Company built upon this audio experience and developed the worlds first all-digital, high efficiency audio amplifier ICs, which it trademarked as Direct Digital Amplification or DDX®. DDX technology became the market leader and in conjunction with the Company's DDX technology licensee, STMicroelectronics, the companies developed over 25 DDX ICs that had total sales of over 35 million devices to leading consumer brands such as Sony, Sharp, Samsung, Harman Kardon, Hitachi, Kenwood, LG, Philips, RCA and Zenith. During the growth of this business, the Company won the Deloitte Technology Fast 50 award in 2004 as the fastest growing technology company in New England" |
#10 | |
Many thanks! |
| spdif to analog converter circuit | Stuw | Digital Line Level | 18 | 11th December 2008 10:29 AM |
| SPDIF in analog sound card | sundeep83 | Digital Source | 1 | 29th May 2008 06:54 PM |
| Analog Ipod out to SPDIF | mitchjs | Digital Source | 13 | 6th November 2006 06:19 AM |
| SPDIF Out for Synth w/Analog out only | electromusician | Instruments and Amps | 3 | 5th April 2005 08:01 AM |
| Page generated in 0.10932 seconds (90.13% PHP - 9.87% MySQL) with 10 queries |
