Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th August 2007, 03:18 PM   #1
theAnonymous1's Avatar
Default CS4329 DC offset
I have a CS4329 based DAC and there is a small amount of DC offset on each channel. I can measure the offset on the input and output of the opamp.
I found this schematic for a different CS4329 DAC board and it looks VERY similar to mine. Could resistor tolerance mismatch be the cause?
http://www.quadesl.com/pdf/cs4329_dac.pdf
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 29th August 2007, 04:36 PM   #2
analog_sa's Avatar
Time to get one of those fancy voltmeters that actually provide readings in numbers
Are you are measuring the same offset at the ouput of the dac (between the two outputs)?
Old 29th August 2007, 05:01 PM   #3
georgehifi's Avatar
Send a message via MSN to georgehifi
When you say a small amount of DC offset, the OPA2132 does give +- 2-4mV in itself which is quite acceptable, what opamp are you using?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 29th August 2007, 05:17 PM   #4
Very sorry guys.
OPA2134PA....
Left input: 1.258v
Right input: 1.267v
Left output: 20mv
Right output: 9mv
CS4329 outputs....
Pin 13: 2.194v - Pin 14: 2.188v = 6mv
Pin 17: 2.206 - Pin 18: 2.205 = 1mv
After closer examination the above circuit is identical to my DAC. The parts values differ a bit though.
Old 29th August 2007, 05:51 PM   #5
Yes, resistor mismatch appears to be problem.
Old 29th August 2007, 10:00 PM   #6
analog_sa's Avatar
Everyone shares the blame: DAC, opamp, mismatched resistors. You should certainly match the resistors as this has an effect on distortion. It is not so obvious what to do with the remaining offset.
Old 30th August 2007, 02:51 AM   #7
Thanks guys, I'll try replacing all the resistors with hand matched values and see what I come up with.
Old 30th August 2007, 07:31 AM   #8
A quick thought...... If I replace the resistors and there is still some offset is there any way to build a trim circuit to null it? A pot across the 5v supply connected to the input of the opamp?
Old 30th August 2007, 08:20 AM   #9
analog_sa's Avatar
There will certainly be offset even with perfectly trimmed resistors.
What you propose is possible but not without issues. The trim circuit will also unbalance the differential gain so other resistors will need adjustment. Using the 5v supply is certainly not a good idea though - it will be injecting ps noise.
Cap coupling is almost tempting.
Old 30th August 2007, 12:30 PM   #10
Are you telling me I'm SOL? Is there nothing that can be done?
I went through great pains to get rid of the caps on the amplifiers input, this offset problem is the only thing keeping me from DC coupling (my goal).
I'll do anything it takes!
EDIT: I think I've got it!
When I put a 1Mohm resistor across R17 the offset goes from 20mv to 48mv, if I put it across R15 it goes down to -7mv. Those two resistors measure 14.93k and 15.01k. A significant mismatch no?
Thanks!
What is DC offset? spooney Car Audio 13 2nd March 2008 10:35 PM
For SALE: NPC 5843 AP1 ; CS4390; CS4329 hifiwolf Swap Meet 8 24th January 2008 04:21 PM
CS4329 help buy GIPIONE Digital Source 0 23rd September 2006 02:43 PM
Help With DC Offset Sybex23 Chip Amps 8 15th November 2004 07:11 PM
10V DC offset JoeBob Chip Amps 8 6th August 2003 11:13 AM
Page generated in 0.10259 seconds (79.64% PHP - 20.36% MySQL) with 10 queries
