Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Digital (DSP) filter
Old 5th February 2003, 09:34 AM   #1
magnus is offline magnus  Sweden
Question Digital (DSP) filter
I've been wanting to build a digital filter for some time. Basically I want a simple board that just accepts S/PDIF, puts it through a DSP with your own algorithms and then outputs an S/PDIF signal again.
Sounds so simple but I can't find info anywhere!
Even if I do 24/96 it shouldn't require a very fast DSP. They all seem to be 1000 MIPS these days. I'm pretty sure I want to do floating point as well. Seems to be the simplest way to get a good algorithm.
So does anyone have a layout or some info or maybe someone already did this?
TIA,
Magnus
Old 5th February 2003, 10:46 PM   #2
dwk123 is offline dwk123
I can't help you too much on the hardware side in terms of current offerings. Motorola used to make EVM boards that would be perfect for what you want - I have 56007 and 56362 versions - they have spdif and analog ins/outs. They weren't cheap though - $400-500 if I remember correctly. somewhat limited in their overall processing power, though, if you ever want to do FIR filtering. More than adequate for IIR/biquad stuff, though.
Many 'purists' will cringe at the suggestion, but you should think about simply using a PC with a good spdif in/out soundcard. Using ASIO under windows or Jack under Linux you can get relatively low latency (more than good enough for A/V sync), and you get to use standard C/C++ dev tools and libraries.
I'm a big fan of the PC based approach, after having played with the DSP hardware boards. Since I'm not a DSP hardware expert, I spent all my time learning the chips/dev tools, and little on actual signal processing work. With something like Jack under Linux (what I'm using now), you get to focus entirely on the signal processing aspects inside a really simple callback framework.
Old 6th February 2003, 03:24 AM   #3
ebrewste is offline ebrewste
You might look at the TI TAS300x or TAS 3103 (newer). I am using a TAS3002 in a project now. It's good for 6 biquads filters per channel.
Old 6th February 2003, 12:54 PM   #4
blu_line is offline blu_line
blu_line's Avatar
There is another cheap DSP also discussed in this forum before.
ohh, sh*t , why cant i remember the name !
I will come up with it !
And what about one of those PC18Fxxx things ???
grtz
Simon
Old 6th February 2003, 01:07 PM   #5
blu_line's Avatar
Default mail me
I have tried to mail you.
It seems you've disabled this function !
mail me instead.
grtz
Simon
Old 6th February 2003, 01:14 PM   #6
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default Sharc boards for sale
you can buy the Analog Devices Sharc DSP EV kit cheaply on EBay -- these are the boards which are showing up:
http://www.analog.com/Analog_Root/pr...RDWARE,00.html
ADI also has an entire textbook on DSP on their website. They make convultion understandable. Even Zipped its a big file, however, and you might want to download it chapter by chapter.
Old 6th February 2003, 01:33 PM   #7
blu_line's Avatar
Default phew, that took a while to find
http://www.alesis-semi.com/products.htm
great stuff
grtz
Simon
Old 6th February 2003, 08:08 PM   #8
Thanks for the info everyone.
I guess this is a tough little problem to solve (cheaply) with a DSP. I definately want to go FIR and maybe 50 coefs. So that requires some computing power.
The PC path is always there but it doesn't really fit in with the high end stuff. So I'm reluctant.
I'll look around some more and see what I find.
Magnus
Old 7th February 2003, 12:21 AM   #9
50 taps is nothing - any dsp will handle this no problem at 44 or 48 - the Motorola 56362 I mentioned previously can do 500-800 at 44.1 for comparison. You may want to think about your requirements, though, since a 50 tap fir may not really be what you want - you could do acceptable brickwall filters for example, but it wouldn't be much use for eq.
Magnus
Not sure what you mean here - with spdif in/out, the quality will be uniform with any of these approaches. Since the clocks will be slaved from your transport, even jitter should be the same. The differences will be in form factor (small, quiet dsp board vs big noisy pc), and in programming environment.
Old 7th February 2003, 06:04 PM   #10
You're right. I do need to find out exactly what I need in terms of performance. 500-800 taps sounds like more than enough. I checked the Mot website and that eval board with the DSP daughterboard looks good. But pretty expensive I bet.
Not sure what you mean here - with spdif in/out, the quality will be uniform with any of these approaches. Since the clocks will be slaved from your transport, even jitter should be the same. The differences will be in form factor (small, quiet dsp board vs big noisy pc), and in programming environment. [/B]
Quality will be unifom, yes. But the big PC case doesn't look so nice compared with the Krell stuff. I want a slick solution.
After looking some more I came up with the Linux/ARM route. Maybe that could be something? Possibly cheaper than the eval boards and loads more software for displays, keypads and whatnot.
/Magnus
Digital (DSP) filterHide this!Advertise here!
Which digital filter to use ? jean-paul Digital Source 18 28th November 2010 08:24 AM
FIR Digital Filter DSP neededandwanted Parts 1 9th April 2009 01:44 AM
FIR Digital Filter PatPet Digital Source 39 8th March 2006 07:40 PM
