AD1955 I/V stage/tube version - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th April 2012, 11:37 AM   #21
Originally Posted by David Davenport View Post
How big is the resistor?
In al that post you didn't say a word about the recomended resistor value by manufacturer and the maximum voltage compliance at the DAC output. DAC's have a "current" output only if the resistance/voltage on that output is zero. They don't have ideal curent sources, therefore any deviation from that virtual zero will translate in increased distortions.
The only I/V converter device that satisfies that demand is the one shown in data sheets (or similar one done with discrete components).
Also, using just one of the outputs instead of the differential mode raises the distortion even more and loweres the signal/noise value.
Old 17th April 2012, 12:35 PM   #22
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
Which resistor ? I/V ?
Old 26th October 2012, 09:43 AM   #23
AD1955 was best DAC on "DAC Final" test, but used with active I/V.
Now you use 200 Ohm on both outputs.
What about sound quality on this configuration ?
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 04:19 PM
high end version of low end phono stage dsavitsk Solid State 20 2nd September 2005 12:51 AM
best I/V stage for ad1955 with discrete components Jaap Digital Source 2 26th January 2005 07:17 AM
Tube I/V Stage TV Man Digital Source 0 2nd September 2003 05:39 PM
Copyright 1999-2017 diyAudio
