Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th August 2007, 04:42 AM   #1
Send a message via MSN to aleksandar
Default Quad Op Amp..............
Hi people
I was plaining to upgrade the OP-amplifiers in my car audio amp JBL px300.4 but i found out that it uses quad op amps version of JRC 2058D so i need advice for some better quality quad op amp.
p.s 2058D has the same electrical characteristics of JRC 4558
Thak you
Bye Alex
Old 26th August 2007, 05:31 PM   #2
macboy is offline macboy  Canada
Burr Brown makes quad versions of their OPA134 and OPA132: they are the OPA4134 and OPA4132. These are both FET input opamps, whereas the 2058/4558 is a bipolar input. They are also much faster than the 4558. Therefore they are not necessarily a drop-in replacement. In order to get optimum noise performance, and to ensure stability, you would need to re-evaluate the other components in the system, such as the value of the input and feedback resistors, etc.
One which is more likely to be a direct drop-in is the National LM837. It has similar performance to the NE5532, much better than the 2058. Specs include: distortion 0.0015%, noise 4.5 nV/sqrt(Hz), GBWP 25 MHz. Most people around here wouldn't call it audiophile quality, but it will be a big improvement.
Old 27th August 2007, 06:43 AM   #3
Thanks for the reply MacBoy
Old 27th August 2007, 04:54 PM   #4
Russ White's Avatar
Send a message via Yahoo to Russ White
The LME49740 would be my first choice...
http://www.national.com/pf/LM/LME49740.html
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 27th August 2007, 11:31 PM   #5
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Mine too...
Regards Åke
Old 29th August 2007, 10:37 AM   #6
Thank again guys for the reply
Also i would like ot ask you one question more about the same amp:
Ive found that it uses TL072CP op Amps from Texas Instruments so would it be nice that i will replace those one with op275 or ad826 because those one i have in the moment, what do you recommend?
Also these op ams i have in the subwofer monoblock amp JBL 1201.1 whould it be nice to replace them also in the subwofer amp so i will get tighter bass............Also this subfower amp uses one JRC A4003B i should replace it with LME49740MA?
TL072Cp
Low Power Consumption
 Wide Common-Mode and Differential
Voltage Ranges
 Low Input Bias and Offset Currents
 Output Short-Circuit Protection
 Low Total Harmonic Distortion
0.003% Typ
 Low Noise
Vn = 18 nV//Hz Typ at f = 1 kHz
 High Input Impedance . . . JFET Input Stage
 Internal Frequency Compensation
 Latch-Up-Free Operation
 High Slew Rate . . . 13 V/ms Typ
 Common-Mode Input Voltage Range
Includes VCC+
The JFET-input operational amplifiers in the TL07_ series are designed as low-noise versions of the TL08_
series amplifiers with low input bias and offset currents and fast slew rate. The low harmonic distortion and low
noise make the TL07_ series ideally suited for high-fidelity and audio preamplifier applications. Each amplifier
features JFET inputs (for high input impedance) coupled with bipolar output stages integrated on a single
monolithic chip.
Supply voltage, VCC+ (see Note 1). . .. . . . . . . . . 18 V
Supply voltage, VCC– (see Note 1) . . . . . . . . . . . –18 V
Differential input voltage, VID (see Note 2) . . . . ±30 V
Input voltage, VI (see Notes 1 and 3) . . . . . . . . ±15 V
Duration of output short circuit (see Note 4) . . . . unlimited
Continuous total power dissipation. . . See Dissipation
Unity Gain Bandwith ...................... 3mhz
Thanks Again to all
Zen Quad 22 johnm Tubes / Valves 0 13th June 2008 03:21 PM
pcb for quad 405 kanjumi Solid State 6 3rd April 2006 05:03 PM
A new Quad ESL?? Audiofool Planars & Exotics 12 17th November 2005 10:00 AM
quad 909 dj_maxxro Solid State 0 4th October 2005 04:11 AM
Page generated in 0.08980 seconds (76.06% PHP - 23.94% MySQL) with 10 queries
