Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
10 MHz oscillator possible to use ?
Old 22nd August 2007, 02:12 PM   #1
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Default 10 MHz oscillator possible to use ?
Any possibility to use a 10 MHz oscillator ?
Reclocking in DAC or whatever.
Old 22nd August 2007, 03:22 PM   #2
lcsaszar is offline lcsaszar  Hungary
It can be used for reclocking if the phase noise is sufficiently low. The exact frequency is unimportant as long as it is much higher than the frequency of the signal to be reclocked.
Let me share my solution: I bought a 1 MHz Motorola TCXO on eBay. It is about 2" x 2" size and the metal can is fixed by 4 screws at the sides. Internal there was a 4 MHz crystal and a 2-transistor Colpitts oscillator, followed by a CMOS divide-by-4 circuit. I opened it and replaced the 4 MHz crystal with a 16.9344 MHz crystal. Initially it did not oscillate, so I replaced one capacitor and it worked. This is now the 4.2336 MHz master oscillator in my Marantz CD-84 player, and I use it also for reclocking the Latch Enable signal of the DAC chips, and also for producing a Dynamic Element Matching (DEM) clock for the same. The DEM clock is divided by 8 and it is 529.2 kHz (12 times the sampling frequency of 44.1 kHz). This is a non-oversampling DAC, and I replaced the TDA1540P 14-bit chips to a TDA1541A.
Old 23rd August 2007, 01:10 AM   #3
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
What were you hoping to improve by doing this? Did you measure and compare the jitter in the original clock and in the "new" clock?
I_F
Old 23rd August 2007, 11:44 AM   #4
Sorry, I have to review what I stated above. The reclocking frequency must be an integer multiple of the original clock frequency or the frequency of the signal to be reclocked.
Old 28th August 2007, 02:37 AM   #5
X.G. is offline X.G.  China
X.G.'s Avatar
Default Re: 10 MHz oscillator possible to use ?
you can use it with ASRC chip,like AD1895A.
Old 28th August 2007, 10:38 AM   #6
I_F
Unfortunately I have no tools for measuring jitter. I am thinking about building one. I could make comparisons only be ear.
Crystal oscillators built around transistor circuits have generally better phase noise than those with ICs. I believe one requirement for low jitter is the low oscillator voltage (preferably sine wave) on the crystal. A tuned LC circuit in the collector also helps. The type of the oscillator (Colpitts, Pierce, etc.) also has influence. Those DIP clocks are built around TTL or CMOS digital circuits, and they have full 5V square wave on the crystal.
Old 28th August 2007, 11:51 AM   #7
Bernhard's Avatar
Default Re: Re: 10 MHz oscillator possible to use ?
Thanks, does it significantly improve jitter performance if used with a very low jitter clock and CS8412 as receiver ?
Just because the clock would be very expensive.
Old 28th August 2007, 10:07 PM   #8
I_Forgot's Avatar
It is not necessarily true that a discrete oscillator will have lower jitter than an integrated one. Especially not if you change the crystal out of the discrete oscillator's design range then start monkeying with caps to get it to start again. Did you use a crystal that is cut for lowest jitter? If the oscillator didn't start with the new crystal and you had to change caps to get it to start, does it now have lower or higher jitter than the original? How does the frequency change affect the spectrum of the jitter?
If you can't measure the jitter to see if there's some improvement it seems sort of pointless to be randomly swapping one clock for another. You might as well be swapping capacitors and reversing resistors to see if you can hear a difference. I suppose if you don't have anything else to do...
I_F
10 MHz oscillator possible to use ?Hide this!Advertise here!
Use of a Ribidum Oscillator as refrence oscillator in a DAC Mark A. Gulbrandsen Digital Line Level 19 2nd November 2014 03:35 AM
Look at this 42V/20A max PSU, and at this low THD oscillator. rephil Everything Else 3 6th August 2006 09:04 PM
oscillator dsavitsk Tubes / Valves 9 15th November 2005 07:07 PM
Oscillator reconditioning maylar Solid State 0 21st February 2004 03:15 PM
Copyright ©1999-2017 diyAudio
