Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CD-PRO2 to DF1704
CD-PRO2 to DF1704
Old 3rd February 2003, 09:38 AM   #1
GUILHERME is offline GUILHERME
GUILHERME's Avatar
Question CD-PRO2 to DF1704
I'm trying to feed the I2S out of CD-PRO2 to a DF1704 chip. The chip is part of a belcanto DAC which works ok if I use it's SPDIF input. My objective is to bypass the onboard receiver and feed the filter directly with the I2S. But I cant make it to work, the DAC just sits there with no sound. I noticed that both the word-clock and bit-clock lines coming out of the DAC on-board receiver are at a higher frequency than those coming from the CD-PRO2. Can someone help me ? do I need to change the clock frequency on the DF1704 ?
The receiver is the CS8240 which has an I2S output. I just cut the lines going from that to the DF1704 and connect the bus coming from the CD-PRO2 to the DF.
Old 3rd February 2003, 12:58 PM   #2
borisov57 is offline borisov57
Beside I2S, you will need master clock on df1704.
Old 3rd February 2003, 01:36 PM   #3
GUILHERME's Avatar
?? sure I need a master clock on the DF otherwise it would not work for sure. At the moment that clock is 24.5760Mhz and that is part of my question.
Old 3rd February 2003, 02:28 PM   #4
maczrool is offline maczrool
I am working with a similar chip, the DF1706. I'm not positive on this, but if the clock is not a standard multiple of the sampling frequency of the data signal, it's not going to work. 24.576 mHz will only work at 48 or 96 kHz sampling rates. Is this what you are sending to the DF1704? Also, make sure the DF1704 is set to receive the same format and interface of audio that you are sending to it.
Stu
Old 3rd February 2003, 03:01 PM   #5
GUILHERME's Avatar
I'm sending 44.1 Khz/16Bit which is what comes out of the CD-PRO2 transport. I'll follow your advice and make a cheap osc with dif freq just to see if it works.
Thanks Stu.
Old 3rd February 2003, 08:38 PM   #6
zelter is offline zelter
Hello,
I just build a dac using the DF1704 + PCM 1704(copy of pass D1).
It is connected via I2S to a CD-pro. I took the clock from CD-pro
(there is a optional connector, see manual).
Everything is working fine.
Did You use the DF 1704 in hardware or software mode.
I used hardware mode. If You want I can send a list, how
I connectet the controll inputs of DF 1704
Greetings
zelter
Old 3rd February 2003, 10:05 PM   #7
GUILHERME's Avatar
Zelter, thats exactly what I want! I'm also using it in hardware. Please do send me the list (post it here or email it). Did you solder the wires to the cd-pro PCB or does yours have a socket fitted on that clock out ?
Many Thanks.
Old 3rd February 2003, 11:04 PM   #8
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
CD-PRO2 to DF1704 Send a message via AIM to Peter Daniel
Posted on a forum. I think there are more people interested in that setup.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 4th February 2003, 04:27 PM   #9
Default zelter's version
Part 1
Old 4th February 2003, 04:28 PM   #10
part 2
CD-PRO2 to DF1704Hide this!Advertise here!
supply regularly CD-Pro2 module VAU1254 CD-Pro (VAU1252) CD-Pro2 (VAU1254/11) vam1250 smartech Vendor's Bazaar 1 10th April 2011 10:02 AM
DF1704 pin out question luvdunhill Digital Source 6 31st January 2008 05:11 PM
DF1704 where to buy? maartentje Digital Source 1 5th February 2007 05:45 PM
CS8415A and DF1704 de-emphasis hagtech Digital Source 2 19th March 2005 09:13 PM
CS8414 to DF1704 wiring Jonnravn Digital Source 2 18th November 2004 07:01 AM
