220V 50hz - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd February 2003, 03:23 AM   #1
Default 220V 50hz
I live at a place with a 230V 50hz supply and intends to buy a DAT machine from the US operating at 110V 60 hz. Using a step down transformer to bring the supply voltage down to 110V is not a problem for me at all but I understand that there will be a difference in motor speeds running at 50hz and 60hz. Is there any way to compensate motor running speeds by varying the volatage supply? What would be the formula to calculate the voltage if its possible?
ckt
Old 3rd February 2003, 05:44 AM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I would be very surprised if DAT's motor speed would be dependant on mains frequency. My Sony DAT runs on 6V battery source.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 3rd February 2003, 06:33 AM   #3
Default Motor Speed
If the motors run on DC, then the mains frequency does not matter at all. For my turntable project which runs on an ac motor, I could change the speed and torque of the motor by manupilating the frequency.
ckt
Old 3rd February 2003, 06:39 AM   #4
I'm afraid that engineering behind TT and DAT motors control is quite different.
For DAT it's more like video camera, or even tape recorder, which obviously are not frequency dependant.
www.audiosector.com
Old 3rd February 2003, 06:46 AM   #5
Peter,
Thanks so much for the clarification. BTW, any experience with the Sony PCM R500 DAT?
ckt
Old 3rd February 2003, 06:50 AM   #6
I'm using portable TCD-D8, which when used with outboard DAC, is almost undetectable from the original recording.
www.audiosector.com
50Hz UPS xyz9915 Power Supplies 4 28th February 2009 09:04 PM
from 120V 50hz to 230v 50hz? testarossa2k Power Supplies 16 13th March 2007 02:32 PM
Wanted: DIY Paradise Charlize, OR Decware Taboo (220V), OR Almarro A205 (220V) Jolojl Swap Meet 0 28th August 2006 12:31 PM
220V/50Hz to +/- 55 volts about 800 watts Szoki Power Supplies 4 9th June 2006 08:43 PM
Converting a 110V 60Hz Garrard 301 to 220V 50Hz icefox Analogue Source 3 10th April 2004 06:15 PM
Copyright ©1999-2017 diyAudio
