Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Need a schematic for a Denon DCM-260 CD player
Old 31st July 2007, 02:42 AM   #1
gaetan8888 is offline gaetan8888  Canada
Default Need a schematic for a Denon DCM-260 CD player
Hello
I've just found a used CD player for a friend.
I would need a schematic for a Denon DCM-260 CD player, especially the analog output section, anybody would have an image or a PDF file of it ?
There is a IC who control the output volume, which one it is and how can I bypass it ?
And I would replaced the JRC-4558 op amps for better ones ?
Thank
Gaetan
Old 31st July 2007, 02:46 AM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Gaetan,
I looked but do not have it. Denon manuals should be pretty reasonable. Give them a ring.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 31st July 2007, 02:48 AM   #3
Originally posted by anatech
Hi Gaetan,
-Chris
Hello
They don't have it as they say it's obsolete cd player, but I just need the analog output section after the DAC.
Do a NE5532 or OPA2134 would be much better than the JRC-4558 op amps ?
Gaetan
Old 31st July 2007, 03:05 AM   #4
anatech's Avatar
Hi Gaetan,
Hmmm. Sorry they don't have it. I am surprised they do not have a record of it.
Are you sure you aren't talking about a JRC 4580? Possibly a "DD" suffix? If it's this chip, it should be a fet input type. It's pretty good actually. (I may have the datasheet for it). Consider an AD OP275. I have the datasheet if you need, but it's just as easy to download. This is not an expensive IC, but a very good performer.
-Chris
Old 31st July 2007, 03:07 AM   #5
Hi Gaetan,
-Chris
Hello
Yes I did read wrong it was JRC 4580 and it was a D suffix.
I have some NE5532 and OPA2134.
I have found the JRC 4580 datasheet, it seem a bipolar input.
Here the schematic of the JRC 4580
Gaetan
Old 31st July 2007, 03:12 AM   #6
anatech's Avatar
Hi Gaetan,
Try the OPA2134 then. Watch it doesn't oscillate. You need to check it muted, silent but playing and with signal. If it stays clean with all these three conditions you should be good.
Pick up some OP275 at some point. Not a bad little IC. If you see any ceramic caps in that section, replace them with mica or polystyrene. That will do more for sound quality than you know.
-Chris
Need a schematic for a Denon DCM-260 CD playerHide this!Advertise here!
DENON CD Player Model 800 miamibob Digital Source 0 30th October 2008 11:01 PM
Denon 3800 DVD-A Player Schematic? dtm1962 Digital Source 0 1st April 2008 04:29 PM
Denon CD player 690G Tubesin Digital Source 0 20th December 2007 01:25 PM
Denon DCD-910 cd player hiss problem fymido Digital Source 0 2nd November 2007 08:30 PM
Denon DCDS10 CD player radar Digital Source 2 16th May 2007 08:13 AM
Copyright ©1999-2017 diyAudio
