diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   Krell CD-DSP upgrades-What's available (http://www.diyaudio.com/forums/digital-source/105875-krell-cd-dsp-upgrades-whats-available.html)
gto127 26th July 2007 04:07 AM
I have a Krell CD-DSP whith a software upgrade IC marked 1991 which I'm sure is not the newest. I have heard they had upgrade IC's until 96 but I don't know how I would obtain one of these. Krell tech support was no help on this-they said they didn't support anything this old. Would anyone know how I could obtain one of these or if I could find someone with the correct IC if it could be copied with a eprom programmer. Also any other mods or improvements for this deck would be appreciated.
wilfredo 22nd September 2007 03:16 PM
we are two in the same ship.
I almost buyng a cd dspfrom ebay at 900 dollars. i want to know if you have a technical report or review from this cd player. it is similar in quality to the MD20 , I had one MD20 but stolen during moving. i amdesperatly to get a good transport for may stealth decoder from krell.
pls anuy help.??? improovement I dont know exactly wich is the chip but i can obtain some info for a friend.
pls tlet meknow you knowledge abot this player .
regards
willly APOKRELL.
gto127 22nd September 2007 06:43 PM
The krell CD-DSP has exactly the same pickup (phillips cdm1mkII) as the md20 but has metal support frame vs a polethelene for the md20. I'm sure since the md20 is a transport only it would be technically better as a transport in some manner but I'm not sure you could tell a difference. My cd-dsp is the best sounding cd player I've ever heard so I would highly recomend it. It sounds so good you might not hear much improvement from your da converter. I actually had a bid in for the player you are talking about but I'm not going to bid again because I would only be using it as a backup in case something happened to mine and it will probably go for alot $1,000+. Good luck on the auction and if you win let me know if there is any difference between the player and da/converter.
wilfredo 22nd September 2007 07:51 PM
ok
ok.thank you for posting
tiefbassuebertr 11th October 2011 08:36 AM
for description recapping project go to post #352 about
http://www.diyaudio.com/forums/parts...ml#post2741758
Copyright 1999-2017 diyAudio
