| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have a Marantz CD-73 and it stopped working a while ago.
Actually it played fine before I put it in storage. Now after 5 years or so it doesn't want to work anymore. The player has now two problems 1.The loading mechanism: When the tray comes out (or actually the whole thing) the motor won't stop(which opens/closes the tray) The same thing happens when you close it. I couldn't find a switch anywere that controls the motor,i suspect it's something electronic. 2.It doesn't read any disc. Who would be so kind to give me hints/tips to repair this 'vintage' cd-player.I just love the design and sound of it. |
#2 |
I know this may be a bit late, but for anyone with a similar problem, this may help.
The loader is dependent on a double leaf switch, which is on the rear of the left hand pcb (internally). This is actuated by a spring mounted plastic lever. The leaf switch can snap, and this can cause the motor to continue to wind. The laser lens should be cleaned carefully (no solvents), and the motor, taken apart, cleaned and lubricated (the grease has a tendency to gum up) . You should make a note of the depth of the bottom (grub) screw before doing this. Neither of these is adisable unless you know what you are doing though. After this is done, and if things still don't work, the next place to look is in the power supply, where all the caps should be replaced, especially the higher voltage and lower value ones. Best to get a service manual before doing any of this, but It can be done without ,if you know what you're doing. |
| Marantz Cd 67 | bull041161 | Digital Source | 4 | 13th April 2009 09:39 PM |
| Marantz cd-32 | ObliVion | Digital Source | 3 | 15th July 2007 09:25 PM |
| Right speakers for Marantz PM8000 + Marantz CD67-OSE? | betto80 | Multi-Way | 2 | 24th May 2005 03:21 PM |
| Link Between Marantz CD12 and Marantz CD99 | Mesh | Digital Source | 16 | 7th November 2003 06:08 PM |
| Marantz T-1 | stigla | Tubes / Valves | 4 | 17th October 2002 01:11 PM |
| Page generated in 0.07266 seconds (68.37% PHP - 31.63% MySQL) with 10 queries |
