| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
#12 |
Here is what Lars Viborg of LC AUDIO did to one, below is the pic, and he said it sounds stunning, even dacs at three times the RRP don't come close.
He instaled a LC Zapfilter MkII for the I/V and Output stage board with a Schoktty Shunt Regulated Powersupply board and Toroidal transformer. And if you want to use it's own transport he put in a XO3 reclocking module and it's own XO Powersupply as well. Major surgery on this one. I think just the output stage mods are enough and use it as a DAC only with a good transpot like Teac VRDS or alike. But then again a clocked internal transport like this could better the external clocked Teac VRDS? Cheers George |
#13 |
Here is a pic of part of the output stage surgery.
Cheers George |
#14 |
Just a suggestion,
The original analog stage uses simple bias solution to avoid a use of sound coupling / DC blocking capacitors. I personally never liked the sound of ZAP filter (too cold, washed-out / sterile). The original IC's are surface mount duals - perfect opportunity to try fast IC's from AD stable, or mellow sounding ones from BB. This will (again, from my experience) most definitely give better results than ZAP filter, for much less money! Boky |
#15 |
Thanks for the suggestions.FET or bipolar OPAMP????
#16 | |
If I were going to do opamp subbing, I would dearly love to use the AD825 smd, but it's a single and I don't know if there is such a thing as a 2 x single smd opamp to dual smd opamp convertor board? Maybe Browndog? In my experience the AD825 is the gun opamp the OPA627 is good also but doesn't have the slam of the AD825, and then I found that the Zapfilter II has even more slam but can on bad cd's sound a bit cold, but really makes up for it with good recorded material, but it's also more expensive way to go. Cheers George |
#17 |
Your in luck Browndog have them @ $6.95 each, you need 4 of them and 8 AD825 's
http://www.cimarrontechnology.com/in...PROD&ProdID=19 Cheers George |
#18 | |
The second IC is half "DC servo", half diff-to-single-end gain stage (for discreet output) - I would try AD826 here. Alternative: LM4562 (different sound, also quite nice...) Boky |
#19 |
No need(IMO..) for any upgrade.
Measurements for HD970 "as is". Jitter bellow 10ps!! http://www.diyaudio.com/forums/showt...79#post1186279 |
#20 | |
Yes it does, the sound standard is a little warm (OP275) and also lacks a dynamics, it also needs more bass slam, this is compared to two other very good dacs. But it can be heard that it's very extended smooth/clean and distortionless, and low in "jitter" if I can identify what jitter sounds like. Saying this I believe it can be achieved, with subbing the OP275 (known to be softish) and the OPA2134 for either better opamps, like my personal favorite the AD825, or to do the radical transplant of a Zapfilter MkII. The latter is extremly dynamic (unbelieveably so) and can sound cold on some sterile recordings, but I belive it's just staying true to the source. Cheers George |
| Harmon Kardon | argonrepublic | Solid State | 2 | 23rd June 2009 07:30 AM |
| harmon kardon T-40 | jaudio | Analogue Source | 0 | 24th October 2007 11:37 AM |
| Mods for Harman/Kardon HD970 | reins | Digital Source | 4 | 11th September 2007 10:01 AM |
| Harmon Kardon PM 640 amplifier | bentley ess | Solid State | 1 | 9th March 2007 08:06 AM |
| Harmon Kardon T40 | jaudio | Analogue Source | 0 | 7th May 2005 12:04 PM |
