Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th July 2007, 10:10 PM   #1
bk.bas is offline bk.bas  United Kingdom
Default TEac T1 output noise
Have just bought a TEAC T1 to replace an aging Marantz that I was using as a transport. I am feeding it into my Audio Alchemy DDE (v1) via the digital co-ax output. When it is first powered on, but before a disc is played it gives considerable output noise, whcih seems to continue even if powered off!. Once a CD is played it synchronises and locks into the DDE fine, and then stays locked until powered off, when the fuzzy crackling returns. Does anyone have any suggestions as to cause. It's not a problem as it plays fine, sounds great (much closer to the 'analogue' sound that I prefer), but is mildly annoying as I can't leave the Amp (Audiolab) switched to CD with the TEAC/DDE combination switched off
Old 22nd July 2007, 02:17 PM   #2
Eric Juaneda's Avatar
Hello bk.bas,
Did you try to change coax digital cable ?
Eric
Old 22nd July 2007, 04:53 PM   #3
Default co-ax replacement!
I've just ordered a new (better quality) one anyway, but the old one which is an ancient QED was OK with the old Marantz/DDE1 combination, so I'll try it and rule it out. If not then still stumped as the 'interference' still continues even when the TEAC is powered off at the mains
ESOTERIC(TEAC) DAC D-500~Noise problem lu64319 Digital Source 0 28th February 2009 04:52 AM
Output Noise question ianc13 Tubes / Valves 2 20th August 2007 10:48 AM
Noise on Aikido output Andypairo Tubes / Valves 35 7th January 2007 09:01 AM
Additional digital output on Teac VRDS players SisterOfMercy Digital Source 35 18th July 2003 11:07 PM
noise from new output transistors peter pkcc Solid State 7 31st May 2001 04:05 PM
Page generated in 0.07125 seconds (71.96% PHP - 28.04% MySQL) with 10 queries
