Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th July 2007, 02:56 PM   #1
soundcheck's Avatar
Default silicon vs. quartz oscillators
Hi folks.
I stepped over this:
http://www.sitime.com/news/articles/NASA_Report.pdf
refereing to silicon oscillators as much more reliable than
quartz oscillators.
I never heard anybody discussing silicon oscillators as an alternative solution around here.
Perhaps somebody of the "clocking" specialists around
here could shed some light on the subject.
THX
Cheers
Old 19th July 2007, 05:08 PM   #2
rossl is offline rossl  United States
rossl's Avatar
I looked at the data sheet for the SiT1 series. They specify 20pS RMS jitter.
There are small, inexpensive crystal oscillators available with low jitter.
Crystec 0.5pS and CTX 1pS. Crystec at Mouser and CTX at Digikey.
The jitter spec is more important to audiophiles than the spec for wide temperature range or the size reduction.
Most of us probably don't need a level of reliability that is necessary for NASA and satellites.
Old 20th July 2007, 09:06 AM   #3
oshifis is offline oshifis  Hungary
While we are at this, what are the usual jitter specs for a TCXO? I have a fairly large (about 2" x 2") Motorola TCXO with an internal 4 MHz crystal, a Colpitts oscillator and a 2-stage 74HC74 binary divider to 1 MHz. I replaced the crystal to 16.9344 MHz, and now it is serving in my Marantz CD-74. Is there a simple home method to measure/estimate/compare jitter values of different oscillators?
Heptode oscillators LoFi Ninja Tubes / Valves 6 14th July 2009 09:06 PM
PSU for HP 103AR Quartz Oscillator ?? redrabbit Power Supplies 11 3rd August 2007 06:32 AM
quartz displacement guytou Digital Source 5 6th May 2005 10:01 PM
Two oscillators replaced by one? Ola Digital Source 2 2nd June 2004 07:44 PM
Page generated in 0.07775 seconds (72.44% PHP - 27.56% MySQL) with 10 queries
