| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Hi all! I have some questions regarding DAC circuit. I've heard that some DACs and AV receivers use multiple DAC chips per channel, like 2, 4, or even 8 chips per channel. They say that using multiple chips improves dynamic range and distortion. But I don't know what rationale supports such a claim. Could someone out there enlighten me on this? Actually, I've even seen a picture where one DAC chip is piggybacked on another chip. And datasheets from Analog Devices (AD1852, AD1853) actually show mono circuits in which ROUT+ and LOUT- (LOUT+ and ROUT-) of a chip are wired together and supplied to an analog stage. If such a scheme is really effective, I'd like to give a shot some day... |
#12 |
Connecting DAC chips in parallel improves the signal to noise ratio and dynamic range. I have not tried it myself so I couldn't comment on the sound. The other option which I am going to implement on my next DAC is a fully balanced configuration. Two DACs per channel one producing the inverted signal the other the non-inverted. A differential amplifier then amplifies these.
#13 |
hi folks
if someone can answer me a question/ it will be appreciated! on my cd player have a 1 bit dac with a 33.868 meg clock, the dac divides that clck to be feed to the servo dsp. the servo dsp generates the l/r data,44.1khz for left & right channel separation & a 3rd signal that i dont know if it is a word clock or bit clock??? this 3 signal goes to the dac again. i made a reshape on the 3rd signal & the inprovment was so huge that i am willing to trade info with someone that can make or design a clock reshaper unit!! thanks richt h |
#14 |
Is the clock generated by the DAC chip and sent from there to the Servo DSP?
The servo DSP will probably send back a DATA line, a Bit clock and a left/right clock. |
#15 |
hi dave
thank you for your info. i made a clock reshape on the bit clock that goes to the dac and the difference was huge!!!! now im going to install the superclock too! thanks richt |
