| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Does somebody know if AD1864 DAC would work at 96KHz 4x oversampling ? Thanks |
#2 |
Have you tried the datasheet ?
#3 | |
Perhaps finding the datasheet is the problem... "The minimum clock rate of the AD1864 is 12.7 MHz. This clock rate allows data transfer rates of 2x, 4x, 8x and 16x Fs (where Fs equals 44.1kHz)" |
#4 | |
#5 |
I have the datasheet.
datasheet says DAC works at 8x oversampling, but its not clear if it works at 48, 88.2 or 96KHz audio signal. |
#6 |
The datasheet is crystal clear and you've been given the answer in post #3.
#7 |
44.1kHz max sample rate... It's an old, old part.
www.kta-hifi.net |
#8 | |
#9 | |
4 x 96kHz = ....? |
#10 |
The oversampling ratio is irrelevant. The dac couldn't care less about it. The limits are set by a combination of the wordlength and the serial clock.
| usb 24 bit 96KHz dac | adib | Digital Line Level | 7 | 24th February 2009 01:54 PM |
| A/D 24bit/96khz convertor help | sunny | Digital Source | 1 | 16th October 2006 12:35 PM |
| USB to 24bit/96KHz | edpgc | Digital Source | 8 | 21st November 2004 01:40 PM |
| 96Khz problems | MWP | Digital Source | 9 | 21st March 2004 02:51 PM |
| AD1855 DAC 96kHz/24 bit stereo | peranders | Swap Meet | 0 | 18th April 2002 08:40 AM |
| Page generated in 0.09094 seconds (77.12% PHP - 22.88% MySQL) with 10 queries |
