Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th July 2007, 07:03 PM   #1
Default DEQ2496 continual reboot(?) Help!
I have a Behringer DEQ2496 that signal wise sits between an SRC2496 and a DCX2496. It has been used in a home stereo for about 2 years.
Starting about 6 months ago I got an intermittent signal cutout during the first 10 minutes of warmup of the DEQ2496.
Now when I turn it on, the front LEDs blink together every ~1/2 second. This is continuous, otherwise nothing else. Is this a cyclic reboot?
I took the cover off and poked around for shorts or burned components, exercised the connectors, etc., - to no effect.
Anybody out there had this problem? Any suggestions? Otherwise I'm looking at 300 clams for a new unit...
Old 16th July 2007, 09:54 PM   #2
I had the same problem with mine when it arrived used via eBay. I removed the boards and put tape down on the bottom of the chassis and put everything back together. It was a stab in the dark, as this method of "repair" fixed a shorting issue I had with one of my DCX's a couple years ago.
So far so good, no rebooting since then. (knock on wood)
Good luck.
Old 30th March 2010, 10:50 AM   #3
simone is offline simone  Italy
Same cyclic reboot here, click/clack from relays & display on/off in an infinite loop.
Stab in the dark n.2 for me: lid removed, exercised PSU connector and... it looks like to work right now without lid on.
Overheat? PSU cable connector?
Is PSU going to R.I.P.?
Old 12th May 2010, 11:46 PM   #4
gphoton is offline gphoton  United States
Default Mine too
Hi, My DEQ2496 from eBay has started to do this too very intermittently. I saw an Amazon review where somebody put heatsinks on the Sharc DSP's to fix their issue. I plan on "all of the above": tape on the chassis, check the PS connector and put some old motherboard northbridge heatsinks on the DSP's. Another poster also mentioned that running the RTA for extended periods leads to issues, which points to a potential heat problems. If this doesn't work the next step would be PS cap and regulator replacement.
Also, anybody know where I can get Seoman's remote control software for this thing? The link is down.
Old 14th May 2010, 06:08 AM   #5
col is offline col  Australia
col's Avatar
You could try the linear PSU mod:
AW DIY - Audio designs for the DEQ2496 and DCX2496
col.
http://www.minirig.org.au
Help me fix my DEQ2496 please... MikeHunt79 Digital Line Level 14 9th January 2012 08:30 PM
Has anybody put a SRC in a DEQ2496? jscoe Digital Line Level 5 6th February 2009 02:20 AM
deq2496 vs rme 96/8 pad back Digital Line Level 0 1st September 2008 05:00 PM
Page generated in 0.08488 seconds (71.61% PHP - 28.39% MySQL) with 10 queries
