Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th July 2007, 02:54 PM   #1
Default OPA1632 + PCM1804 question
Hello, I am designing an ADC input stage for the PCM1804, usign the OPA1632 differential opamp. Reading the opamp's datahseet, I found a recommended circuit for this implementation (see attachment). The question is: is it necessary to buffer the VCOM pin of the A/D, or can I connect it directly to the Vocm pin of the opamp (perhaps through an RC filter)? Thanks a lot.
Diego.
Old 4th July 2007, 03:57 PM   #2
Keruskerfuerst's Avatar
The datasheet of the PCM1804 does not mention the output impedance of the Vocm pin.
Advantage of the additional op: lower impedance of the Vocm source.
Disadvantage: maybe higher offset.
I would say: just try out both circuits.
Houston, we have a problem!
Old 4th July 2007, 04:40 PM   #3
Thanks for your answer. I noticed the lack of information regarding the output impedance of the Vocm pin, but the input impedance of the VCOM pin of the opamp is 34Meg, according to the datasheet.
I'll follow your suggestion and try both circuits.
Diego.
OPA1632, I/V and VOCM 00940 Digital Line Level 9 7th August 2009 10:14 AM
OPA1632 and THS4131 x-pro Parts 3 21st July 2007 04:19 PM
PCM1804 bal/unbal adc meta Digital Source 14 7th February 2007 06:44 AM
PCM1804 acting up MC Digital Source 6 6th April 2005 05:54 AM
PCM1804 -> TAS5015, Analog PWM amp fr0st Digital Source 0 26th August 2003 12:59 PM
Page generated in 0.08068 seconds (69.79% PHP - 30.21% MySQL) with 11 queries
