| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello!
I need a schematic for a mini switcher with a few components only. It has to be powered by AC 220V in has to produce DC 12V. It will be used as PSU for one relay and IC 4027. I supose that 500mA should be enough. Does anyone have an idea how should this be done? I was hoping that i could use an IC, but i'm not sure that it is possible. Regards, DJG |
#2 |
For a relay and a single gate, you probably need more like 20 mA, not 500. Just buy the smallest transformer you can find or buy a small AC\DC power supply. ST has a linear regulator that I believe you can get 20mA out of. Designing a switcher for AC use is just not worth it at low volumns.
#3 |
Would you perhaps know the exact label of that ST? Or do you might have a schematic of it?
thx |
#4 |
National Semiconductor LM2954 series of "Simple Switchers" will work great for your application.
BeanZ |
#5 |
No, it wont. disregard that last post. I forgot about your 220V input requirement.
BeanZ |
#6 |
Try making a Royer Converter from the rectified AC line. It would require a transformer with a primary, a secondary, and two aux windings. Also, two resistors and two transistors. Your transformer should be a "square" B-H material such as Permalloy 80 or Orthonol. Good Luck!!
BeanZ |
#7 |
what about one of these ?
http://www.futura-shop.com/pdf_eng/1350-VB409SP.pdf - only about 30 mA tho Or You can use a cap. to reduce mains voltage. Be careful with mains plz
#8 |
Yes, this VB409 is the right thing for me!
-Just one question - where to buy? I looked over all the shops in Slovenia, but they don't have it DJG |
#9 |
If you are only driving a relay and a mini IC, it would be best to just use a low frequency main transformer with rectifier and cap filter. The previously mentioned part will dissipate huge amounts of power and will require a heatsink. Also the minimum output current on this part is 80mA much higher than your required minimum. You may have trouble there.
BeanZ |
#10 |
I don't know... I realy don't want to use a transformer.
I guess I'll have to ask directly: How should I build a button-switch, witch would control 1kW toroidal trans.? DJG
Mosfet rules! In any prospect! |
| My DIY Pre amp switcher pops! | MuthaFunk | Parts | 5 | 6th May 2009 02:07 PM |
| WTB: abx switcher | garlandstephens | Swap Meet | 8 | 2nd December 2006 09:41 PM |
| Anyone use an offline switcher PS for GC? | speaker | Chip Amps | 4 | 26th March 2004 01:02 PM |
| Partridge Oil Filled C-Core Chokes 1H @ 500mA | mozfet | Swap Meet | 1 | 28th October 2002 07:27 PM |
| Aleph-X with less than 500mA total bias | jwb | Pass Labs | 1 | 10th September 2002 09:35 PM |
