| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am modifying my Sony SCD-C555ES. In the IV and output sections, the signal input ground, the output ground, and the power supply ground are all isolated (although they are connected somewhere outside of the audio board). I cannot make much sense out of this design and believe that it creats problems for high frequency singals. Any thoughts on how to connect the grounds without creating a large gound loop?
CT |
#2 |
Hi
Your observations are correct One should use a closed groundplane to avoid signal loops. On my site, I have a PDF with advise on how to layout a circuit board Currently my site is down due to hosting transfer, but you should be able to find yout way tomorrow best |
#3 |
I look forward to see your site.
CT |
| Speaker ground issue | lowfrequency | Everything Else | 6 | 4th December 2008 01:20 PM |
| Parallel LM3886, input ground, power ground, safety resistor and oscillations. | markiemrboo | Chip Amps | 5 | 9th August 2007 03:50 PM |
| Ground issue | ctong | Pass Labs | 2 | 26th June 2007 12:24 AM |
| LM3886 p2p - ground issue | Stabist | Chip Amps | 0 | 20th January 2005 02:03 AM |
| does connecting mains ground with circuit ground create a ground loop? | jarthel | Everything Else | 0 | 25th June 2003 12:55 PM |
| Page generated in 0.07713 seconds (70.10% PHP - 29.90% MySQL) with 11 queries |
