| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Looking for an upgrade to Vishay-Telefunken BYV-27-150 diodes wired in parallel for my TDA1541A Dac. I've seen references to:
- Silicon Carbide Shottky's like CREE - Regular Silicon Shottky - Harris FRED - HexFred - IXYS, including HyperFred Anyone upgrade their standard soft recovery diodes with one of these with clearly improved results? I'm looking for more resolution/detail from my TDA1541A NOS dac. Finally, anyone care to recommed the same for my DRD300B amps? Thank you!
Cheers ~ Mike |
#2 |
I'm also interested if anyone tested these http://www.qspeed.com/Products/About...Rectifiers.cfm
Regards, Tibi |
#3 | |
best |
#4 |
Thanks Guido for your feedback!
Brand, specs please?
Cheers ~ Mike |
#5 | |
Hello Mike, Actually I haven't encountered Schottkies that sounded worse than regular silicon. Types I use often in my modules and modifications are: SS16 (smd) D15XBS6 (15A/60V bridge from Shindengen, great company) SB160 (1A/60V wired) SB360 (3A/60V wired) Another advantage of SB's is lower forward voltage drop hence less heat development. best Guido |
#6 |
many thanks Guido!
Cheers ~ Mike |
| FS: Lot of IR rectifier diodes | luvdunhill | Swap Meet | 1 | 4th February 2009 02:19 PM |
| rectifier tube recommendation please | gary h | Tubes / Valves | 5 | 9th July 2008 01:39 PM |
| Rectifier diodes for UcD 400 | m.parigi | Class D | 6 | 14th March 2005 09:42 AM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Rectifier Diodes | richie00boy | Parts | 6 | 19th April 2004 01:41 PM |
| Page generated in 0.09029 seconds (77.31% PHP - 22.69% MySQL) with 10 queries |
