Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Best resistors For I/V Conversion?
Old 18th March 2016, 12:52 AM   #21
Bidule is offline Bidule  France
What would be the best for TDA1543 ?
What do you think, in this case (TDA1543), of susumu smd resistors (RG2012P-102-B) 1K/0,1%, SMD0805 ?
Old 18th March 2016, 02:31 PM   #22
savinalexandru is offline savinalexandru  Romania
Originally Posted by savinalexandru View Post
The bulk foil Vishay resistors for I/V stage that some of you are using are the same with ''Z201 Series''?
Have anyone of you noticed sound difference, lets say, between 0.05% and 0.1%?
Kind rgs,
Alex.
So digging deeper, seems that are two series:
VAR series, that is naked Z-Foil, audio grade
Z201 series, that is plastic cased
Same question remain, have you used VAR series or Z201 for your I/V resistors?
Have a great weekend!
Alex.
Old 19th March 2016, 01:40 AM   #23
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
NSL32SR2S???
You could try one of these to see what it sounds like in this very low power position.
You could use NSL32SRS that I use in the "Lightspeed Attenuator" and fix the led brightness to it to give the R value you want. Many including myself believe they sound better than any type of resistor, being made from CdS (Cadmium Sulphide).
And you could vary the R on the fly by changing the led brightness to find your optimal listening preference.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 19th March 2016, 02:47 AM   #24
jcx is offline jcx  United States
Bruce Hofer of Audio Precision, in his Analog Master Class seminars, mentions that the best 5ppm thin film R are the real deal for measured low distortion at audio frequencies
Originally Posted by jcx View Post
it appears that Hofer is saying that some bulk metal foil don't perform proportionately as much better than some thin film just considering TCR
a guess would be that the extreme low TCR are obtained in part by balancing mechanical strain and TC of substrate and foil - so there is a more complicated thermo-mechanical effect that doesn't work to full benefit above fractional Hz and below kHz
but the foil still has as low TCR as any thin film as far as I know – so it shouldn't actually be worse than thin film – just not as much better as might be expected by the DC TCR ratios
it would be useful to know which “some bulk metal foil” are that show this – Z foil? - differ between chips, leaded, “naked”, fully encapsulated? as well as the numbers, plots
Old 19th March 2016, 07:52 PM   #25
Eldam is offline Eldam  France
Banned
Originally Posted by georgehifi View Post
NSL32SR2S???
Cheers George
Hey, : It could work with such as low current ?
Old 19th March 2016, 08:35 PM   #26
georgehifi's Avatar
Yes and the led works on 5vdc in the Lightspeed , which you have inside most dacs, so no power supply need to be built.
Someone should give this a go, it very strange I didn't think to try it, before doing the AD844 http://www.diyaudio.com/forums/digit...ad844-i-v.html for I/V stage.
Cheers George
Old 20th March 2016, 12:34 AM   #27
Chris Daly is offline Chris Daly  Australia
Cheers George
If you want it to sound miserable, the problem being an awful presumption that digital 5v+ power lines
are suitable for LDR's - go ahead
Old 20th March 2016, 01:13 AM   #28
georgehifi's Avatar
That's a bit rich coming from the one who tried pushing this "miserable" opamp pass transistor idea onto the unsuspecting.
Op amps and Pass Transistors
Cheers George
Old 20th March 2016, 02:13 AM   #29
Damon Hill is offline Damon Hill  United States
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
Vishay's bulk metal foil material comes in several grades, the Z1 foil is their current most stable material, the rest is mostly in packaging to absolutely minimize temperature coefficient. Bulk foil, thin film and wirewound resistors are all typically made of nickel-chrome alloys (with 'secret' ingredients); the foil is much thicker than metal films and has a much better voltage coefficient. This is an advantage shared with wirewounds over thin film, especially very high resistance films. High stability wirewounds may rival bulk foil resistors in sound quality, and I tend to think of bulk foil resistors as miniaturized wirewounds.
There are some very stable metal film resistors, such as Vishay/Dale PTF series, that approach foil resistors in temperature stability. These may sound better than run-of-the-mill 100 ppm TC metal film resistors.
Vishay offers enhanced stability grade Z-foil resistors that are 'pre-aged' to remove the last traces of drift (generally below .005%), and hermetically sealed in oil to further enhance stability by eliminating moisture and oxygen from affecting the foil and to heat sink the resistive element. They'll be priced accordingly and I wouldn't bother with them, just that those resistors are probably the 'ultimate' in stability over time and environment, where absolute value is important, as in metrology applications.
I don't think there are any great differences between metal foil resistors that are rated by tolerance, such as 1%, .1% or even .001%; just that they are stable enough to hold that tolerance over time. That's slightly more desirable.
I've found RNR series metal film resistors that are hermetically sealed in glass with argon (or helium?) and gold leads, but these are just metal film resistors with a military/ aerospace grade reliability and environmental protection. The resistor element and end caps are clearly visible through the glass package (no paint) . I doubt they are 'special' in any audible sense, but I don't think audiophiles have yet 'discovered' these parts and have tried listening to samples.
There are some other materials used as resistive elements, such as tantalum nitride that may be of similar quality to nickel-chrome alloys, but they are uncommon and I've never used those types.
Old 21st March 2016, 12:41 AM   #30
quantran is offline quantran  Viet Nam
Send a message via AIM to quantran Send a message via MSN to quantran Send a message via Yahoo to quantran
Takman Rey is very good. Transparent, neutral and non-fatigue sound.
Quan Tran
Best resistors For I/V Conversion?Hide this!Advertise here!
5 Watt Resistors on Aleph 4 and Holco Resistors nicharis Pass Labs 16 8th February 2012 07:50 AM
FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers chris-man Swap Meet 1 28th May 2009 11:47 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
Resistors for ultralinear-to-triode conversion spendorspain Tubes / Valves 6 28th January 2007 12:47 PM
Inductive resistors for source resistors bbakota2000 Pass Labs 12 25th March 2005 11:33 AM
