| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I've already looked at Stencils Unlimited, but it's a little pricey. I'm using ExpressPCB, so I'm limited to dxf files. Have any of you guys made stencils for your pcb's, and if so, how? Thanks.
#2 |
I bought one from SU. Excellent quality. Also bought paste & other stuff. Used a fancy toaster oven and it all worked fine. Except where the 0603 were close together, I ended up getting solder bridges as the resistors and capacitors floated on the metal and moved slightly. Normally everything floats and centers itself. With the tight spacing I got diagonal shifts.
In the end, I chucked it. Turns out I can solder everything by hand just as fast. And it never requires touch up or rework. I see no reason to go to stencils for small jobs. They're only practical and cost-saving if the boards are machine placed. If it is the SSOP type devices you are having trouble with, try the technique outlined in this video: http://www.hagtech.com/media/solder.wmv jh |
#3 |
Do you have a recommendation for a vacuum? (Oh, and thanks!)
#4 |
"Soldapult"
jh |
#5 |
I think a Soldapullt is too big for surface-mount work, although it is the cat's whatever for through-hole stuff. Desoldering braid is better for this miniature stuff.
(once upon a time I thought DIP components with 0.1" leadspacing were small... now I'm soldering stuff I can barely see.) |
#6 | |
#7 |
It was very windy that day. It's the garage-type door banging. Not the most professional video. I just did it in one take.
jh |
#8 |
Hi, can you give us a little background on what you're trying to do? If it's just a one-off hobby project, I would look around for a local contract PCB assembly company and get them to solder it for me (if I can't do it myself).
In the past I've ordered several stainless steel stencils from MasterCut for the company I was working for. But for that kind of thing you need to liaise with the assembly guys to find out exactly what they need.
Lech |
| First DIY. Suggestions are welcome. | RomanSivers | Multi-Way | 3 | 19th December 2006 04:29 PM |
| SET Suggestions | nogoodboyo | Tubes / Valves | 37 | 11th March 2006 08:38 AM |
| need suggestions please.. | oface | Full Range | 2 | 23rd March 2005 04:46 AM |
| DAC Mod Suggestions? | Flappytango | Digital Source | 24 | 4th February 2004 04:25 PM |
| Any suggestions | jaybird | Multi-Way | 3 | 15th January 2004 09:12 PM |
| Page generated in 0.09947 seconds (75.85% PHP - 24.15% MySQL) with 10 queries |
