Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th June 2007, 10:43 AM   #41
stoolpigeon's Avatar
SAA7350 + TDA1547 is what became known as DAC7 and is a fairly ordinary performer, majoring in blandness, IMHO.
Just use it as is and put your energy into something better eg TDA1541A
or PCM63 for the more patrician
Old 15th June 2007, 12:32 PM   #42
Fin is offline Fin
Fin's Avatar
Originally posted by harrygrey382
could this be right behind the button and display area?
The important one that you will need to find will most likely be on the main board....with a lead from the display/control panel connected to it.
It has already been suggested that one possibility is to exclude the TDA1547...and use the SAA7350 as the DAC.
Fin
Old 15th June 2007, 12:43 PM   #43
Then you would just have a fairly ordinary player majoring in ordinariness.
Old 15th June 2007, 05:35 PM   #44
It hasn't got SAA2003, closest to that in jnumbers is SAA2001, also with SAA20011, SAA20031 SAA20041 SAA20051 PC74HC4046AT a Mitsubishi M51581 and a 'Japan 41464AJ-08'
Any luck there?
The M51581 is the digital input.
Old 15th June 2007, 05:39 PM   #45
ok so I need to retain the digital circuit with that on it, and the coax must go through this, with the analogue out just from the DAC board?
Old 15th June 2007, 07:42 PM   #46
Unless it is on a separate board and you feel up to making a new input board.
Old 15th June 2007, 08:03 PM   #47
well it is on a separate board, with all those SAA chips I mentioned. But I was thinking I'd just link the two boards and make new regulating circuits for the 5V and 12V and leave it at that.
Old 15th June 2007, 08:28 PM   #48
If you have the space, might as well do that.
Old 15th June 2007, 09:16 PM   #49
well I can make the space. I'll be asking a few more basic questions once I start I assume. Thanks for the help guys
Need advice converting B&W 602 s2 into 3-way doobie Multi-Way 26 15th March 2009 10:12 PM
Converting TO-220 to TO-247 Clipped Car Audio 5 24th July 2007 06:59 PM
Converting a DAC-in-the-Box to I-out? Aleksunder Digital Source 0 26th May 2007 11:44 AM
Converting a DCC into a DAC harrygrey382 Digital Source 0 21st May 2007 10:10 AM
Converting Bl ht_boy Multi-Way 2 12th December 2005 04:32 AM
Page generated in 0.11325 seconds (78.04% PHP - 21.96% MySQL) with 11 queries
