| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
There is a small possibility someone here may know if this problem is fixable.
The tray on my Vrds 25 started misbehaving.It closes normally then there is a small whirring noise that was not there before as if it is trying to lock but cannot and then the tray opens again on its own.No play is possible. I have schematics of the player but tray mechanisms are beyond me. I am very wary of having it serviced here in Brazil.
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´ Morgan Jones, Building Valve Amplifiers. |
#2 |
Bump.
#3 |
DIY !
Checked rubber-belts? ( 8 )
Ars longa, vita brevis |
#4 |
DIY !
the other: ( 19 )
Arne K
#5 |
Hi Cobra,
These plans could be very helpful.I only have some electronic schematics.Are these all you have on the transport?Are they for the vrds-25 ? I cannot see some parts like the tray itself and the clamper mechanism. I hope I don't have to take apart everything - looks like 100 pieces there -phew!
#6 |
DIY !
They are for VRDS-25, which is the same as VRDS-10...
Arne K
#7 |
I fixed a similar problem on my VRDS-25x just recently. The tray loading mechanism is covered by the "bridge" piece that holds the VRDS clamp. To remove it I did the following:
1. Remove all three parts of the top cover. 2. Remove the loading tray. 3. Remove the DAC pcb (on the left). 4. Remove all screws of the two top connecting pieces between front and back that divide the top cover in three parts. 5. Remove the ribbon cable just left from the right connecting piece. 6. Move the two connecting pieces 2-3 cm towards the outside in order to get access to the four screws that attach the bridge (holding the clamp) to the underlying drive mechanism. 7. Release the four srews and lift/move the VRDS clamp to get access to the tray loading mechanism. Good luck! |
#8 |
Ok Mr.Katana man
,Was your problem the same i.e. the tray would not stay closed etc.? When you say you fixed it , what did you do apart from accessing the tray mechanism as you describe?Did you replace or adjust anything? If you could reference this to the diagrams supplied by Cobra it would help. Thanks
#9 | |
If in your case the tray is also hard-steering the problem might be the same and the tray re-opens just because there is too much resistance. If you think the loader is running smoothly you have to look elsewhere. |
#10 | |
Also for the drawer replace the belt, part # 8 from the first schematic and your player should be as good as new. |
| TEAC VRDS-10 vs VRDS 25X | Pani | Digital Source | 12 | 3rd April 2011 04:03 AM |
| Teac VRDS-10 problems | tfboy | Digital Source | 11 | 8th September 2009 05:46 PM |
| Help please with Teac VRDS-T1 | georgehifi | Digital Source | 0 | 14th February 2006 02:40 AM |
| TEAC VRDS-10 .. need help ! | picodelle | Digital Source | 2 | 7th November 2005 10:21 PM |
| Teac VRDS-10 problems | Cobra2 | Digital Source | 2 | 10th October 2004 11:22 AM |
| Page generated in 0.10787 seconds (77.05% PHP - 22.95% MySQL) with 11 queries |
