| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Can I have some opinions please on the best sound card for 2 channel playback. No recording, no multi channels just good old stereo.
As per the subject, sky's the limit! TIA Jim |
#2 |
If you want a 2ch playback only soundcard, you'll probably have to make it.
#3 |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
ESI Juli@ is a very good sound card
http://www.esi-pro.com/viewProduct.php?pid=43&page=2
Regards Robo |
#5 |
If you need to know what DAC and chipset mount different soundcards take a look here http://www.head-fi.org/forums/showthread.php?t=229391
I know that Onkyo SE-90 and Audiotrak Prodigy HD2 (who is commercialized only in Korea) was born to have only stereo output, but it don't mean that they are the best. Onkyo SE-200, for example, have a stereo output who is considered better that SE-90, because have a better DAC. |
#6 |
Or, if your objectif is play music from a pc and send it to your external amp, you can choose an external usb stereo DAC and use it like an external soundcard.
Go here, you can find a lot of info http://www.head-fi.org/forums/forumdisplay.php?f=59 |
#7 |
Using a soundcard with a good SPDIF output (transformer coupled) like the M-audio Audiophile 2496 in combination with an external DAC is probably the best solution, but if you don't want to do that I recommend this. It uses the Envy24HT chipset, and a Wolfson DAC. You'll want to replace the op-amps and coupling capacitors for best analog output though.
#8 |
frugal-phile(tm)
The best ones are going to connect to your computer via Firewire, and aren't going to be called sound cards per se.
http://www.digitalaudio.dk/ax24.htm (credit to Fast Eddy for pointing this one out on another thread) The AMR CD player could also be used as a DAC. Also Wavelength. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 | |
#10 |
I'm building the DI-16 DAC from ecdesigns. There's a thread on it 150 pages long or so - Ultimate NOS DAC.
I'm building it purely for 2 channel sound to hook up to my martin logan speakers. It has USB input on it, and it's own external power supply. |
| PC sound card sound chips | kaluchka | Chip Amps | 6 | 20th June 2011 03:48 PM |
| USB sound card | Jennice | Parts | 57 | 17th June 2008 09:07 AM |
| Looking for a New Sound Card for my PC | samsagaz | Everything Else | 46 | 18th March 2007 04:39 PM |
| Can your sound card do this? | jackinnj | Everything Else | 25 | 7th November 2005 11:32 PM |
| Suggestions: Cost no object driver, approximately 300Hz - 8KHz | alvaius | Multi-Way | 11 | 6th February 2003 01:51 AM |
| Page generated in 0.10016 seconds (78.16% PHP - 21.84% MySQL) with 11 queries |
