| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi Folks,
i would like to tun-up my Marantz CD-60 and i need some assistence to build it to a NON-OS by using the TDA1541A ! I read a lot about the 1541A here in the DIY-Audio Forum but i canīt apply direct to the PCB ! I got the Service Manual and I want to change a lot of Partīs like exchanging all Resistor where Sound passes to NON-Magnetic by Vishay-Dale or all standart CAPīs relaced to bigger ones by Nichicon MUSE and Panasonic FC Gold Series ! Normal Foil CAPīs out and MKT in. DIODES like 1N4002 kicked by Schottky or IXYS-Diodes ! But the MAIN-THING is to make a NON-OS Player ! Does anyone got experience with the CD-60 and can help me ? Also witch one is better Nichicon MUSE, Rubicon or Panasonic FC ? Vishay-Dale or TKD Resistor ? best regards Carracho
Marantz CD-60 // Sony CDP-415 pimped //Musical Fidelity Elektra E20 // Musical Fidelity Elektra E30 |
#2 |
Have a look at this : www.tnt-audio.com/clinica/cd60pc.html
All in all, I think, the best modification for cd-player is the analog outputstage... The most succes you get is to change op-amp circuit into discrete outputstage, if it isnīt even in your model..(donīt know this marantz..) For what reason reason ever, discrete outputstages sounds better than the best OP-Amp ![]() Why?? |
#3 |
thx Random
I Know tnt-audio ! On this site Peter Campell tunes a CD-60 Output OPA and on the next steps he gives a cleaner Voltage to the TDA1541A nothing else :-( ! I intent to listen this OPīs AD275GP OPA627 AD825 OPA2134PA OPA2604AP then i will hear witch on touch my taste ! I have contacted ecdesign.nl ! watch here in diyaudio they have a lot TDA1541A project ! So mayby these guys can give some hints t apply NON-OS direcly on the PCB !
#4 |
Non é mai abbastanza... |
#5 |
THX aparatusonitus !
I just finishet on Thursday ! ;-) Great ! I find the same INFOīs you send to me :-) thx anyway
#6 |
@ aparatusonitus
did you allready disabled the Digital Filter by cuting 3 lanes ? sounds a little bit more stable ;-)
#7 | ||
#8 |
Sorry for that long Delay :-( a little bit bussy . . .
This disable the Digital OUT ! You can use the SAA7220 as a low Jitter clock by cutting Pins 6 7 8 ! So it get no Digital Data more ! no Input no Jitter ! Thats makes the Sound more stable , immediately !
#9 |
Hello,
do anybody know if the non-os mod from Marantz CD 60 can be do at the CD 40? Thanks. Aronier |
#10 | |
| Tuning at or below Fs | tech.knockout | Multi-Way | 23 | 3rd February 2012 02:06 PM |
| Tuning BR below Fs? | 00600 | Subwoofers | 28 | 11th November 2008 02:09 AM |
| Marantz CD 7300 Tuning | Kal | Digital Source | 6 | 28th July 2006 11:55 AM |
| I need help with box tuning!!! | jking29 | Car Audio | 8 | 21st December 2005 04:37 AM |
| need help tuning TL sub | zobsky | Multi-Way | 18 | 1st September 2004 02:09 PM |
| Page generated in 0.12025 seconds (77.40% PHP - 22.60% MySQL) with 11 queries |
