| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
To all DITB modders, changing to 12V regulators, please note as follows:
IMPORTANT: I found a serious error in the published schematic- I don't have the datasheet in front of me here, but if you look at the CS8412 data, you will find that it takes a feed from the audio power supply & audio ground for "clock recovery". It is marked on the schematic as coming from the 5VD in error. So, when you change to 12V regulators for the audio output supply(which I hope you did), you MUST add a small 5V regultor IC(i.e., the tiny 78L05 removed from audio supply) to the line going to clock recovery pins of the CS8412, as that pin is rated only up to 6V, and explains why I have had a CS8412 fail on a previous DITB. (very kindly reported by Stephensank) |
| Best OpAmp for Audio Alchemy DITB | arupg | Digital Source | 58 | 23rd November 2010 12:56 PM |
| Op Amp Upgrade In Audio Alchemy Ditb D/a | arupg | Digital Source | 16 | 7th December 2006 08:28 AM |
| audio alchemy ps 3 | PAICE69 | Swap Meet | 0 | 24th March 2006 08:33 PM |
| audio alchemy help | HIPCHECK | Digital Source | 2 | 1st June 2005 07:11 PM |
| Audio Alchemy DDE v1.0 mods/schematic | Tutordennis | Digital Source | 0 | 24th September 2004 12:41 AM |
| Page generated in 0.05603 seconds (74.67% PHP - 25.33% MySQL) with 10 queries |
