| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Anyone has the experience to fed NOS TDA1543 DAC with 176.4khz resampling signal?
I just finished my NOS TDA1543 DAC kit and fed it with some test signal and observe the output with a oscilloscope. The sound card is Prodigy 7.1 XT which is capable to produce up to 192Khz digital signal... however, my diy nos dac can only lock at up to 176.4khz 44.1khz sampling rate: Sine wave 10khz: ![]() Sine wave 20khz: ![]() The 20khz one exactly looks like the waveform in the Kusunoki San's paper... However, when I fed with 176.4khz sampling rate data: Sine wave 10khz: Sine wave 20Khz: Looks more like a sine though... Square wave 20khz: (44.1khz sampling rate) (176.4khz sampling rate) ![]() I don't have good audio equipment in hand so no listening test... Just want to ask if anyone have experience to feed NOS DAC with resampling data? If I play music using foobar2000 and resampling to 176.4khz...any benefit?(looks like the waveform is better...) or any disadvantage? Thanks! |
#2 |
I'm using 88.2 for that purpose (foobar2000) (my receiver chip does not lock good at rates above 96k) and it sounds better through speakers than plain 44.1, so no problems I can see by using 176.4.
Deep down inside. |
#3 |
I use CS8414 as the receiver chip.
Seems that it is a "96kHz" digital audio receiver. I don't know why I can fed it with 176.4KHz sampling rate data. Interestingly, the phenomena only happens when CS8414 used in master mode. If I switch CS8414 to slave mode and use a 11.2896MHz oscillator as the re-clock. The waveforms remain the same as 44.1KHz sampling rate ones. I think it is because I lock the sampling rate to 44.1KHz (when using re-clock) regardless what data I input to CS8414. Seems that I have to choose from better waveform (resampling to 176.4KHz and not re-clock) or lower jitter (re-clock)... Don't know what is more important...any comment? |
| USB soundcard for laptop 24bit with resampling | Jonasa | Digital Source | 12 | 16th September 2007 06:39 PM |
| long or short ribbon for 4khz+? | thadman | Multi-Way | 0 | 16th June 2007 08:16 PM |
| Creating a differential signal from a single-ended signal for bridged amps | Peter Daniel | Chip Amps | 45 | 8th November 2004 12:47 PM |
| Need a GOOD resampling program | Rainervs | Digital Source | 37 | 2nd June 2004 02:41 PM |
| "Signal Lock" Indicator for CS8412/TDA1543 | Nisbeth | Digital Source | 7 | 5th January 2004 09:02 PM |
| Page generated in 0.08753 seconds (72.52% PHP - 27.48% MySQL) with 10 queries |
