| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
RCD 965 Muting Transistors to a Relay. How? (components or something I buy/install)
So I can see the four (half round) Muting Transistors T109 - T112. I understand I can clip or desolder them and don't need jumpers. Many say afterwards, they hear little or no noise and pops. Others say they hear different degrees of noise and pops with power off/on and changing CDs/tracks. All say the musical improvement is amazing! So I am moving forward. It seems Muting relays are a superior solution. No pops or noise and the musical improvement is the same as removing the transistors. This is what I prefer but will settle (like it would be settling) for just removing the muting transistors. So here is the question and what I need help with: Do I add any certain components to make a relay or is this something I buy already made and install? Can you recommend which components or relay I should use for this CD Player and direct me on the best way to install them? Or is this a huge undertaking and I should just remove the transistors only? All help, as always, will be greatly appreciated! Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner? |
#2 |
I hate to see you had no responce but anyone that dare answer could be faced trying to teach too much online.
You can use the transistor to drive the relay coil and the relay contacts would then short the signal to ground, direct if the output stage can handle that or through a resistor if it can't. Google for basic electronics web sites and learn how transistors and relays work, from this knowlage you will get what you require. |
#3 |
First, you should find good relays i.e. Takamisava RY or NY series add to this control transistor and shund diode in parallel with relay coil. In internet there are many relay usage schematics.
There is no miracles, just short circut and circut brake. |
#4 |
Gentlemen,
I thank you both for responding. I was feeling like Tom Hanks in Cast Away. Stones, that yellow road sign you have had me ROFL. I have the unit apart now so I need to learn way too much way too fast. YIKES. I appreciate the info you posted to get me started. I am hoping for a link with a kit or something complete if there is such a thing! S_volkovoy, Thanks for taking it a step further so I can use better search criteria when searching Google. Fans....Keep those cards and letters coming! Thanks all! Regards//Keith
#5 |
Ok litle more help for you the link to the main page here is in the wiki on this site but for u help to learn 4 u
Its does not matter about relay quality so much as it will never be in the signal path (unless you are in mute, who cares at this point). |
#6 | |
Daisy Bell |
#7 |
If you using ralay to short signal to ground you don't need a very high quality signal relay, small size and low cost is prefered.
#8 | |
Daisy Bell |
#9 |
Usualy smaler relays works faster. And on more, MUTE circut switches with delays, so 0.1s - 0.3s for switshing should be enough.
#10 |
Thanks everybody!
Looks like a reed relay and a diode for each channel will do it and reusing 2 of the four existing transistors. Now I have to figure out which reed relays and which diodes (hint, hint). I am not sure of the voltage I have available from the transistor and/or PCB and how to attach what to where. I will keep searching and reading. Most of what I find is so generalized, I am afraid to move. I haven't found anything on an exact situation like mine (output stage muting transistors converting to a muting relay on a CDPlayer and how to work with the PCB). Frustrating how much garbage you have to go through, even on Google. I have to give you all a lot of credit for sticking to this and learning as much as you have! Have you ever seen the movie "The Matrix"? I wish I could get a couple of those downloads into my brain! But Smith seems like a pain in the butt!Regards//Keith
| Muting Relay ..... buzzing | Baldin | Solid State | 13 | 18th May 2009 05:59 PM |
| Muting relay problem | decky | Solid State | 23 | 23rd March 2008 07:29 AM |
| muting transistor>relay,can i do this? | Rodzilla | Analogue Source | 1 | 20th August 2004 12:22 PM |
| Muting: alernatives to mechanical relay? | paulb | Solid State | 29 | 31st December 2001 07:37 PM |
| Page generated in 0.12087 seconds (76.62% PHP - 23.38% MySQL) with 10 queries |
