Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd May 2007, 02:48 PM   #1
Default TOS to SP/DIF coax
Hello guys,
I am using a Sony x303-es player as a transport and a seperate DAC. My Sony player only has a optical digital output and no SPDIF coax. In some threads I read that a SPDIF coax signal has less jitter and is therefore better.
Can I convert the optical signal to a sp/dif signal in this way (see my drawing)?
Thanks,
Chris
Old 2nd May 2007, 10:51 PM   #2
dangus is offline dangus  Canada
Your arrangement might work, but the voltage levels will be much higher than standard S/PDIF.
Check out this page: http://www.epanorama.net/documents/audio/spdif.html
When I added S/PDIF coax out to my LD player I used the "Simple S/PDIF output without galvanic isolation", but you could try the "Simplest TTL to S/PDIF coax interface" which is basically the same but without the buffer chip.
I've heard that the transformers on old 10BaseT ethernet cards can work for S/PDIF but I haven't tried them.
Old 3rd May 2007, 08:00 AM   #3
Hi Dangus,
Thanx for your reply. The link looks very helpfull!
I'll post my results here.
Old 30th May 2007, 01:59 PM   #4
promitheus's Avatar
Hey 123chris did you try that out.
I want to do the same thing to my CD Player but I haven´t found a solution.
Is there a KIT out there or a ready PCB?
Old 30th May 2007, 02:16 PM   #5
Hi promitheus,
Not yet. First im waiting for a tent clock to arrive. I will build that first. But after that I will try one of the options from the given link.
Old 30th May 2007, 02:27 PM   #6
promitheus's Avatar
Are you going to make a pcb or just put it on a universal pcb?
Old 30th May 2007, 04:39 PM   #7
I think I'll put it on a universal print (experimental). I didn't find any complete kits for it.
Old 30th May 2007, 06:10 PM   #8
ruerose is offline ruerose  Canada
You can purchase a small adapter for your purpose.
Here in canada, The Source sells them.
http://www.thesourcecc.com/estore/Pr...roduct=4208561
Based on this, it might not be much of an improvement since it is an external conversion. Conversely, you can likely assemble your own converter. Can't be that difficult for the capable as the box only sells for $40CDN.
My preference is Optical, since it is a non-conductive connection.
Old 30th May 2007, 06:19 PM   #9
promitheus's Avatar
I found the digital input to the Toslink output.
Is this TTL?
if so I could convert this to S/PDIFF coax with a small circuit.
Is it easy to find the I²S data lines and how can I interace them to the outside world? I mean what kind of connector and what kind of cable should I use for this?
Old 30th May 2007, 06:25 PM   #10
Is this TTL?
Mostly the input for your Toslink LED is indeed TTL level. Do you have a service manual?
Cheap OB coax? jimluu Full Range 2 31st July 2008 03:43 AM
Coax & DBR Thorsolar Multi-Way 4 14th July 2008 09:33 PM
Help with design for EV Pro-12B Coax botrytis Multi-Way 29 9th May 2007 08:40 AM
10" Coax in OB inrank Multi-Way 27 12th September 2006 02:20 PM
hum from tv coax bonsai171 Everything Else 17 4th April 2004 05:25 PM
Page generated in 0.13284 seconds (76.82% PHP - 23.18% MySQL) with 11 queries
